220 engine swap
Agcosucks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Agcosucks Quote  Post ReplyReply Direct Link To This Post Topic: 220 engine swap
    Posted: 18 Mar 2024 at 9:14pm
Opinions on swapping a 7080 motor into a 220?
Dkranawetter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dkranawetter Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2024 at 9:34pm
Good luck champ, back in my day we didn’t take good tractors and tear them up for pulling reasons.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2024 at 9:55pm
Just google 220 or 210 Allis and look at the pictures. A bunch. Just look at which way the oil filters point and the intercooler. 3500 vs 670 block. ...and this is the pulling forum...only issue is lower radiator hose...fan...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Agcosucks Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2024 at 9:59pm
The 7080 motor is going into my 220 puller. I know the blocks are cast different but it should bolt up the same I assume?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2024 at 10:07pm
Yes, as stated IF you are talking complete swap, the location of lower radiator hose and the 220 has a hyd drive pump set up intact.  If you have intentions of a front plate swap for a different pump you have a lot of fabrication anyway. The 7080 has the preferred counterbalanced crank and the ability to run an inline pump w/o a harrison style drive as the pump hits the block on the 220 w/o relocation.
