220 engine issur6
Trenthorn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trenthorn Quote  Post ReplyReply Direct Link To This Post Topic: 220 engine issur6
    Posted: 15 Aug 2025 at 5:56am
Looking for help. Was just finishing up this 220 restoration hoping to put hood on it and take it to a show tomorrow. This tractor hasn't ran in 30 years. Every bolt on the thing has been touched besides the rear end and transmission. Engine was overhauled. I got it started today for the first time and it ran perfect for 5 min and stopped hard at idle. I thought the crank locked up even though it had oil pressure. Come to find out the bearing for the hydrualic pump drive locked tight and snapped the camshaft. From what I can tell oil is supposed to sling down on the bearings through 2 holes but there is no way to put some oil in there when assembling everything. Just trying to figure out what I did wrong to I dont have it happen again once its back together. I dont know how bad the damage is yet besides a broken camshaft and cracked cover and bent a couple push rods.
1956 WD45, 1970 190xt Series 3, 712,716,917
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2025 at 6:30am
Pack the bearings in grease like a wheel on a wagon. The shaft/bearings (when assembled) spun easily by hand ?? They CANNOT be pre-loaded at all as they are high speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trenthorn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2025 at 6:34am
What kind of grease do you recommend not to hurt the engine? It was only the back bearing. Should I be able to just replace the bearings and races or should I look for a different hub? It turned easy by hand before assembling. These are original bearings as I felt they didn't need replacement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2025 at 6:43am
I use a light white grease called Lubri-plate. Anything would be better than dry, including Vaseline. I don't think you can get the housing on wrong, right ?? It only fits one way. I imagine the hollow shaft/gear is fine, but I'm not holding it my hand to look at it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trenthorn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2025 at 7:32am
No housing only goes one way. I haven't tore the bearing apart yet.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2025 at 8:32am
You didn't happen to leave out the spacer ring between the two bearings? I think that a new bearing set comes with a new ring??
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2025 at 10:32am
He didn't take the assembly apart, just washed it out. That's why he could not pack the bearings. I wonder if using some 90wt would have been a good way to pre lube it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2025 at 10:38am
Anything better than washed out with solvent and dry.
This page was generated in 0.180 seconds.
