220/3500 engine rebuild 'kits' |
Michael V (NM) ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: NM Points: 2486 |
![]() ![]() ![]() ![]() ![]() Posted: 03 Apr 2020 at 9:19pm |
well, the more I'm messing with this unwanted, neglected stepchild, I'm finding that it became a really bad etherholic in its lifetime,,,, evidence shows from all the ether can caps found in the caked up dirt, toolbox, and other hiding places..lots of blowby, no starting without the ether,,
so, I ask what are y'all using for rebuild "kits" I'd like the best for the lowest $$,,, yea,, I gotta budget too..with that said,, this tractor will prolly never see them 14-18 hour days at full load pulling a plow,, but I'd sure like to be able to.. in other words, it needs to "earn its keep",,, oh yea, this will be 'out of frame' so extras will be needed, such as new/rebuilt oil pump, new cam bushings/bearings, complete head/valve job and whatever else ....prolly new clutch/resurfaced flywheel since I'm there... Reliance kits are what I'm seeing mostly,, are there others? I'll look at the vendors that support this site first...
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5044 |
I've had excellent results with Reliance kits.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22071 |
Generally, the oil pump is never replaced on an AC engine like that, especially if it is the crankshaft driven oil pump.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8658 |
I doubt you need oil pump or cam bearings. Be sure whoever does valves knows it matters where the valve head height is. Low seats and ground valves cause LOW compression and hard starting.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7518 |
I would definitely replace the cam bearings. Many engines just get an infame rebuild - throw in new rings and pistons and away you go. Can bearings get ignored. The cam bearings on my 190 XT were worn down to bare metal. If you are going to rebuild it, take the extra time to go right through it just to make sure there are no problems that could crop up 100 hours later. My 2 cents.
Alvin M ![]() Orange Level ![]() Joined: 24 Jun 2018 Location: PA Points: 804 |
I Move The Valves .010 Closer To The Pistons It Will Start Better Also On 301 Engines Been Doing It For 40 Plus Years
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8367 |
How do you do this Alvin with the valves?
Install New Seats Then Machine Them .010 Less Then Specs After Head Is Machined
Thanks for the info Alvin, bet you know alot more tricks that are very valuable !
Amos ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ontario Points: 1318 |
Doug, Alvin knows !!
