21C PROJECT
AC Mel View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Topic: 21C PROJECT
    Posted: 22 Jul 2022 at 3:03pm
Well everyone knows we have more AC projects started and less finished than anyone on the forum.....well hell...lets start another one.
Many of you know that all our timberland and range land burned in 2017.  So we did some salvage logging and a minimal amount of cleanup.....always planning on a big assault on site prep brush raking.... both for forestry planting and range land improvements.  Still not enough hours in the day....so I did an evaluation in the yard and thought...ok what's the biggest tractor we have that we could make serviceable the quickest...... How about a 21C!
Been sitting for quite some time but we got it started and moved to the wash rack
So grandson Trenton is on the pressure washer......then we'll be on a search for the brake problem.
As I mentioned in the video.....we might have some access to this FD30 for parts
We believe all the 30 parts are interchangeable with the 21C
If we can get this thing serviceable...we'll look into the FD30 parts.
Edited by AC Mel - 22 Jul 2022 at 3:09pm
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2022 at 5:41am
Mel
What engine in the FD 30?
A couple neighbours have around here have Iveco V8's but seems some had Cummins
From the neighbours there is a modern starter that is a lot lighter and more effective.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2022 at 8:30am
i have not been on a 21C for 30 years... Always enjoyed operating them.
The FD30 was a new version of the 21C... The FD30 had the V8 IVECO engine and a new transmission based on the FD20 Italian tractor... I think the torque converter was the same... Basically the final drives and steering were the same or very similar.. I think thats what Mel means.... should be a lot of "parts" that can move from one tractor to the other..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2022 at 9:11am
Geesh theres some metal there! What does it weigh ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2022 at 9:40am
fully loaded with the ripper and blade............ your in the 80,000 pound range.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2022 at 10:19am
Kind of makes my FD5 look like a toy - but then the FD5 sure out worked the HD5B it replaced . Looks like the Grouser Bars on the 21C never met the ground
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2022 at 10:49am
Uncle had a 69 HD 21 with the Ateco hinge ripper as the orange 21 on the left of Mel's one picture without a ROPS was over 42 ton.
I did not know the FD 30 was that closely related to the 21's. As uncle had one of those too after a wile.
Did the late 21's and FD 30's have improvements to final drives?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2022 at 12:23pm
Is the UC associable to any other machines Mel, or is it that same unobtanium as most Allis?
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2022 at 4:47pm
fwiw HD21 track chains are 9.00 pitch. . .same as D8H.
Many moons ago when i was young and had hair. . . we took the track chains off a customers HD21A and put them on his early D8H.  Think we had to add 2 links ??
tits tyres and tracks
they all cost you money
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2022 at 5:34pm
That is a good thing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2022 at 6:59pm
Ray
We had a nest of Allis owners around here - 16's and 21's.  Story I heard is that 21's had a problem with expanding the eye of one of the final drive bearings which was fixed in 21C's.
Seems that the 16's didn't have the problem.
rcwitzel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rcwitzel Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2022 at 8:03am
AC Mel - I have a binder full of Fiat-Allis 21-C service manuals.  They cover final drives, engine, cab, steering clutches and brakes...etc.  The binder includes an operations and maintenance manual.  Most look like they just came out of the printer.  Send me a private message if you want them.
R.KYLE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.KYLE Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2022 at 7:41pm
GOOD INFO. MOST INTERESTING.
This page was generated in 0.176 seconds.
