210 Alternator charging issue
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Topic: 210 Alternator charging issue
    Posted: 07 Jul 2017 at 10:16pm
Tonight I put a new rebuilt alternator on my 210...I have been fighting dead batteries for the year I have owned it.  I have new batteries and new cables and new alternator in it now.  I volt tested at the alternator and the battery and it shows it is not charging (12.3 volts).  I have power to the alternator and have tested the ground wire to the alternator also...if I unhook the field terminal it should charge no matter what correct?  It still only reads 12.3 volts.  Alternator is spinning good and freely.  Did I just get a bad rebuilt or what else can I test.  Thanks for any help.
Matt Folkers
FOLKERS RESTORATION
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 11:38pm
I haven't worked on our 210 yet, it is still a project waiting, but by the looks of the parts book is has a remote voltage regulator up under the dash cover like the other hundred series, and Two Twenty/D21 tractors.  I would look there.  Also check your grounds on that regulator.
Still in use:
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 3:56am
You need the field terminal to be connected. I presume you have an external regulator, since you mention the field terminal. If you don't have an external regulator and your alternator has a field terminal, I would presume that you have the wrong alternator installed. If you have an external regulator and it is connected, that regulator may be your problem.
ranger42 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger42 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 8:59am
I had the same symptoms on our 210 it was voltage regulator on the hood under the cowl cover like others guys have said. I did have one other time we were having trouble and it was a bad ammeter gauge.
