210/220 hydraulic question
ToddnwIl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Topic: 210/220 hydraulic question
    Posted: 31 Mar 2023 at 7:02pm
We have a pull dirt blade that needs 3 hydraulics to work. Could we tee off of the 3 point hitch and use that leaver also without damaging anything? Wouldnt get a tremendous amount of work but would be nice to just have it hooked up. And be fun to play with our toys in the field!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2023 at 7:14pm
You can easily tie up/block up the 3-point hitch, tap into one of the hoses going to a lift cylinder and use that lever as a one-way "raise" only and gravity down lever.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2023 at 9:02am
Dr. Allis is right.  The 3 point hydraulics are only single acting - no down pressure.
This page was generated in 0.301 seconds.
