210/220 fan belt help
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Topic: 210/220 fan belt help
    Posted: 13 hours 36 minutes ago at 10:01pm
The pulley on 210-220 addition that will help wrap the water pump pulley and crank pulley. This is a special flat pulley used on F series and other Gleaner combines .  Remove the inner bolt on the front timing /pump cover and install longer bolt with shims to align pulley. Works to lengthen life of belts.  PN 71178651
Edited by tbran - 13 hours 29 minutes ago at 10:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 58 minutes ago at 9:39am
Hydraulic pump drive idler.....currently  $57.39 at my dealer.
