210 220 7000 series wheel push bolt thread size |
AndrewGubbels ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: nebraska Points: 1517 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Jul 2015 at 6:54am |
Hey guys Does anyone know what the threads are on the pusher bolts for the latest style cast wheel wedges? As on a 210 220 7010 on up through the 8550? I tried a 7/8 Standard thread and Fine and it is something different. Any thoughts? Thank you!
Andy |
Andrew Gubbels
Gubbels Restoration |
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5113 |
they are 7/8" but an odd thread, I think 12 is the pitch.
Butch(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842 |
Seems to me it was posted that some Case/IH uses same 7/8-12? Might try there if they are closer than AGCO
I just looked at my tap for this, and it is indeed 7/8"-12.
Kevin in WA ![]() Orange Level Access ![]() Joined: 08 Feb 2010 Location: Lynden, WA Points: 612 |
It is special, I bought a tap from Enco years ago for this, I will check to see what it is.
Great! Thanks for the input guys! Always appreciate everyone's help!
Andy |
Andrew Gubbels
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4545 |
I found that there is a thread that is called 'Industrial thread' that is neither coarse or fine. Found it on the adjusters on roller mills that I sell. More heavy duty but not well known. Could that be it?
Unit3 ![]() Orange Level ![]() ![]() Joined: 17 Oct 2009 Location: NC Iowa Points: 5604 |
How many do you want?
