2012 F250 2WD Front Rotor Removal |
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3607 |
Topic: 2012 F250 2WD Front Rotor RemovalPosted: 20 Mar 2020 at 4:04pm |
I got two that are stuck on. looked at a bazillion you tubes. ![]() I think this model is spose to slide right off the hub with a little persuasion. I been up to a 4 lb hammer and also tried the pushing with a bolt and nut through the caliper mount. I can't get these things to budge. Oh and used ample krioil. I hope somebody can bail me out on this one. thanks. Edited by Dave H - 20 Mar 2020 at 6:02pm |
Red Bank
Joined: 18 Apr 2018 Location: Germanton NC Points: 1051 |
Posted: 20 Mar 2020 at 6:22pm |
Keep beating from the backside out. When you put the new ones put some anti seize around the center of the rotor where it meets the hub.
fixer1958
Most of it is rust on the inside of the rotor that expands and won't allow it to slide over the hub. Wail the chit out of it on the horizontal 'hat' part of the rotor to knock the rust off. It will help dislodge it from the hub too. If you have a light you can see behind it where the caliper mounts. If you think you have enough spray on it give it another shot. Select your words carefully. It takes the right succession of profanity to make the magic work.
Joined: 11 Sep 2009 Location: illinois Points: 90793 |
Posted: 20 Mar 2020 at 7:10pm |
are you sure the disc is not part of the hub ? "SOME" 2 wheel drives were made that way
Dave H
Posted: 20 Mar 2020 at 9:27pm |
Dang Steve, I did not find that you tube. It looks exactly like my 2WD Ford. I am going to yank that puppy apart tomorrow and go from there. Thanks, If you don't hear back shortly, no news is good news, but I will get back. AAAArrrgggg, I can't believe it is gonna be 27 degrees in the am.
shameless dude
Posted: 20 Mar 2020 at 9:44pm |
tannerite or....trade it in for a good truck!
sho-man1
Bronze Level Access
Joined: 14 Sep 2009 Location: Wylie, TX Points: 196 |
Posted: 22 Mar 2020 at 8:13am |
My son was making a run to Little Rock to pick up a motorcycle using my F250SD.
He made is about an hour out when he heard clicking/rattling noise from front drivers side hub bearing. Told him to limp it back to Greenville, TX and I would bring more tools and we can change bearings. I get to the O'Reilly's parking lot, he has the left front hub off but can't get the bearing inner race off the spindle., bearing was shot. O'riely's and autozone didn't have a puller. The other O'riely's in town has a puller, i start to head over there but see a Greenville Fire truck and command truck setting across the street having a casual meeting. I swing by and ask them if any mechanics shops might be open at 7am on a saturday and explain what is going on. They all jumped up wanted to take a look. Them fellows rolled up, popped out the jaws of life and an air chisel. They had the race off in a few seconds. The crew from Station #4 went well above community service to help us out. So now we have a Northern Tools air chisel, would love to pickup a hydraulic or electric jaws of life. The fireman pinched the race then started working that thing off, would not budge. Air chisel with about three hits and it was gone...
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12418 |
Posted: 22 Mar 2020 at 8:21am |
Some have a single or 2 screw on them to hold it in place while you put the caliper together. Small screws, but could hold you up.
I had one come off in pieces last year. |
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 22 Mar 2020 at 12:19pm |
A lot of them were 1 piece
Bill_MN
Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Posted: 22 Mar 2020 at 3:26pm |
First time I changed brakes on my 2013 F150 I had to thoroughly beat the wheel off because it was seized to the middle of the hub. The pilot hole surface on both the wheel and disc tend to seize from electrolysis, takes quite a bit of persuasion sometimes.
john(MI)
Posted: 22 Mar 2020 at 3:55pm |
Did you stop by the station house with a couple dozen donuts?
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 22 Mar 2020 at 4:58pm |
John, they're all low carb keto eaters now days.
Dave H
Posted: 23 Mar 2020 at 5:13am |
Thanks for the interest folks and especially to steve(ill) for posting the vid. My ole Ferd "get it" is back on its feet and outta of the barn. ![]() That was also a reassuring post about the fire men (oops i meant persons) folks.
