Forum Home Forum Home > Allis Chalmers > Farm Equipment -Knowledge Base
201 engine assembly
 Post Reply Post Reply Page  123 4>
Message Reverse Sort Order
 Rating: Topic Rating: 2 Votes, Average 5.00  Topic Search Topic Search  Topic Options Topic Options
W Speedy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote W Speedy Quote  Post ReplyReply Direct Link To This Post Topic: 201 engine assembly
    Posted: 05 Oct 2020 at 5:49am
Marv,
Did you have a shop manual for the engine assembly? If so, which one? There’s a few out on the market.
I have a 46’ W Speed Patrol getting ready for a rebuild this fall, the block is at the machine shop now.
I’ve rebuilt a few engines over the years, but the brass shims were something new to me.
Thanks,
Bill
ihscout View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ihscout Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2018 at 5:33am
Thanks for the reply believe me I've done that myself I believe I found an engine on this forum that somebody is selling rebuilt I think I'm going to go that route
'40 AC B - My Pappy always told me "Use your head for something other than a tack hammer!" I did. It makes a great 16 pound sledge hammer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2018 at 3:49pm
Click on farm equipment and upper left should have start new topic.
Welcome!
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2018 at 3:46pm
It depends on what you need.
I found a set of sleeves. pistons, rings and O rings at a real good price. After I bought a gasket set, main bearings, rod bearings and cam bearings, I had more money in it than if I had bought a complete kit.
After I took the head to the machine shop, I found out I needed a complete valve set. Now I'm way over what I could have bought a kit for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ihscout Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2018 at 2:23pm
Sorry to slip into your subject matter here but for some reason they won't let me start a new topic. I'm rebuilding the 125 cubic inch engine in my 1940 B tracker anybody got ideas as to the best and cheapest rebuild kit
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 9:57pm
I am going to fix the pictures in this post as time allows.
The mechanic always wins.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 6:33am
Using resistance plugs have an immeasurable effect on ignition timing. what they Do affect, is mag coil inter winding voltage. When resistance wire or plugs are in a mag circuit, the voltage which appears in the mag coil is substantially higher. it's very hard on the coil insulation.
the reason for resistance wires or plugs, is to suppress harmonics... dining between the plug gap and ignition coil of a battery-coil system. when a high tension coil arcs across a gap, the magnetic field of the coil collapses rapidly, and it tends to ring like striking a bell. this running causes incredible radio interference, which doesn't play well with radio receivers, computers, and other electronics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 6:27pm
That video was shot like 10 seconds after the initial startup. I had the mag in centered in the slot. Since then I moved the mag all the way out and it does sound much better. I tried to retime it the way Tom said above, but didn't seem to make a difference. I still have to have it out all the way to run its best. But yes, you are correct. If you move the mag back, it does sound like it's laboring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 8:16am
Sounds excellent- it's hitting very evenly on every cylinder.
Now, it could be the audio quality, could be sound level... and it could be that it's just still breaking in... but it sounds like it's laboring a bit. How much advance is it indicating now when running?
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2016 at 11:12pm
O.K., finally got some time to mess with the video of the engine running. I created a youtube account and up loaded it there. So lets try this-
https://youtu.be/Kx8D3ydmMsg
I will try and make a better video when I get some free time.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 8:23pm
Way to go Marv! There's nothing like hearing your engine run for the first time. Hope you can get the oil leak fixed. I never saw one leak like that. The WD45's even had an oil line dumping oil on top the gear and they didn't leak that much,
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 5:52pm
I use wire core spark plug wires on all mags.
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 4:27pm
The only way to fix the timing is to move the governor gear.  You'll need to pull that out again and get the drive slot horizontal when your pulley set screw is pointing at the floor or at the ceiling.
It seems odd that there would be so much oil coming out from that small shaft that it would make a mess anywhere but the front of the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 11:54am
Thanks Tom. I will try retiming the mag because that bothers me that it runs the best when pulled all the way out. Makes me wonder if it would run better if I could move it more.... I may even start it, and remove the two bolts and turn the mag past the slots to see if it gets any better. It starts good, and I think it runs good, but I just wonder if it couldn't be better. I have to do something on that governor shaft. The fan is blowing the oil onto the rear fenders. I have a nice thick square cut rubber grommet that I may slip on there to at least slow it down.
Has anyone ever heard of using newer spark plug wires causing problems because the spark actually gets to the plug faster, which actually advances your timing? Because when you pull out on the top of the mag you are retarding it, no?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 9:25am
On that oil leak, since there is no seal there they will all leak there.  The front of these engines all would be very caked with oiled grime there.  Factory designed flush system. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 9:21am
Great pictures!
To get your mag to be vertical when timed correctly the mag drive slot needs to be horizontal when at TDC.
If you point the rotor at the tab for one that is when it will fire while running and will be 30 degrees before TDC.  I would mount the governor with mag drive first then put the mag on it, with the mag at horizontal you will see the rotor is a bit after the timing tab in the cap.
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2016 at 3:24pm
Hip Hip Hip Hooray!!! She's running!!
Hope that the oil leaking around the governor shaft is an easy fix.... Wink (Famous last words, but I still hope that....)
'39 Model B
Tractors are cheaper than girls, remember that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 10:03pm
Way to go!
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 9:49pm
Well, I had a fellow I work with rebuild the mag for me. I meant for him to show me how, but the two of us are so busy we could never find an hour to set down and go through the dang thing. He has all the parts in stock and rebuilds them regularly. So, got the set screw on the crank straight down, pointed the rotor at the plastic tab, and bolted it up.
Had to modify the gasket, as it didn't have a hole for the locating pin.
Got a universal wire set from Fleet, and some Autolite 295s.
Dumped in 5 quarts of 10w-30 and a bottle of zinc,
I plan on running 15-40 in this motor, but figured I'd run 10w-30 for a break in oil. Filled the radiator, and the air cleaner cup, dumped a few gallons of non ethanol in the tank. Checked the tranny oil as well.
Hooked up a mechanical gauge just to be sure on the oil pressure.
And cranked her over. Actually started pretty good, I think. I shot a video of it running, but I'll be danged if I can get it to upload.
It has about 12 psi oil pressure, might add a shim to try and bring that up. Coolant temp at the water manifold seemed to settle in to 150 degrees.
Of course, I hopped on and took it for a spin up the street quick. All gears seem good.
I loosened the mag, and moved it back and forth. It seems to run the best when I pull the top of the mag away from the block, like this.
Now the bad news. There is oil leaking out of the governor shaft. I knew this was egged out, but didn't think there was that much oil up there, Apparently the governor and gear train must fling it around in there pretty good. Can a guy drill that out and bush it or something?
More to come.... thanks for looking!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2016 at 1:37pm
Originally posted by trackicker trackicker wrote:
Hello, I'm a new-be to this site. Enjoying this engine build.
I have an H3 crawler with a 149cu I'm overhauling and wondering if anyone has some technical specs or at least experience with the block deck height. First, I have no idea if the block was surfaced in the past. It was warped .005, I knew someone with a mill and though I was ahead of the game expense wise...but it came back to bit me. It's unclear how much was taken off and will take a bit more to get squared up again.
So now I'm wondering how much can be taken off before it becomes a problem, I don't want to end up needing av-gas to run thing.
any 2 cents is welcome...
Welcome!  If you want to get some additional answers to your question, please go create a new post in the "Farm Equipment" section and ask the exact same question (even though this is a crawler - same engine as some tractors) - you will get far more responses.   Posting this question in someone else's post is not considered good form.   This particular post is here in the knowledge base to help others doing an identical engine and the original poster is  updating his progress as he goes along.   Interjecting your question in the middle breaks the flow of his rebuild story.   Good luck.   Mike
Edited by Skyhighballoon(MO) - 27 Jul 2016 at 1:38pm
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2016 at 12:51pm
I would say the compression increase would be negligible.You will likely find the counter bores are not square will the deck now(deeper on one side).
trackicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trackicker Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 4:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 12:47pm
To plug the crank I picked up some tapered corks from the local hardware store. Dug out as much of the wick as I could reach with a small pick. I put one cork in the front side, and think I actually drove two in from the back.
The pilot bearing almost slid in by hand, so I took a center punch, and staked or peened the bore where the bearing goes. That raises little metal to hold the bearing in. Make sure the end of the input shaft fits into the bearing before installation.
Bodnarboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bodnarboy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 8:31am
Hey guys.....I made rookie boo boo and trimmed my rear main felt seal BEFOFRE I watched Don's video. New one be here tomorrow..Question for Littlemarv..I would like to use a sealed pilot bearing like yourself as it appears there was a lot of leakage judging by the inside of my clutch housing. Was it a direct fit? and if you don't mind what is there any special procedure for plugging the crank with the cork? I greatly appreciate all of your help thus far. I plastigauged my crank and the shim kit from Sandy Lake worked great. I have water jacket and rocker assembly installed. Your post has been a lifesaver!!
Billy
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2016 at 1:01am
The pilot bearing fit pretty easily, so I staked the bore a little with a center punch. That, and a little green Loctite should take care of it.
Torqued the flywheel on, and marked the two "F" marks, and the TDC one that lines up with the setscrew on the front pulley. Not sure if I will need them or not, but they are easier to see.
Lined up the disk and bolted the pressure plate on.
Got the manifold on as well. Made my own studs. The short ones are from a 3406 Cat, and the two long ones are from Fastenal. Also got some thick 3/8" washers, and two 7/16" washers for the center two studs.
Edited by littlemarv - 02 Sep 2017 at 9:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 9:06pm
Littlemarv,
 You have a WD group following you!
Welcome Forum newcomers, sounds like your lost in the 50's like me!
(With 7 tractors from the 50's)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bodnarboy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 8:29pm
Littlemarv,
Took that second look and lined up like a charm! Thanks a MILLION!
Billy
WDDave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WDDave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 7:55pm
New to the forum,
Great job littlemarv with your rebuld, I will get there one day.
I wanted to ask DaveKamp if there are any fixes for a crack between the intake and exaust port as he described other than head replacement?
   I will know better when I get 1/2" of grease scrapped off but I think I have a crack in that area.
I have a 1950 WD with 4" tall head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bodnarboy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 5:18pm
Littlemarv,
I apologize for spelling your name wrong in last post! You truly are a life saver! I have come a long way on my build thus far and don't want to fail now. I will definitely take a close look tonight after supper :-) Your post has been a huge help!
Thank you
Billy
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 3:57pm
It appears that I have washers under the nuts because I DO have washers under the nuts. Page 4 of the WC parts and operating instructions book. Item number 32, quantity 12.
Take a close look at those three holes on the cam and gear. They should only line up one way.
This page was generated in 0.252 seconds.
