201 engine assembly |
Page <1234> |
Bodnarboy
Joined: 18 May 2016 Location: Denton Maryland Points: 27 |
Posted: 02 Jun 2016 at 8:19am |
Thanks Allis dave!! I did get confused it appeared that littlemerv had washers underneath his bolts in his pictures above. I do have a really important question yet stupid on my part. I am ready to assemble my cam gear back to the camshaft, however, I have zero idea what position it goes on as the 3 holes could allow it to be assembled 3 different ways. I imagine this is a very important step....I bought the WC Service manual but didn't locate any information on it.
Thanks Billy Bodnar |
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3121 |
Posted: 01 Jun 2016 at 12:45pm |
The head stud nuts just take a regular grade 8 nut. No washers.
Edit - Head bolts should use washers. Edited by Allis dave - 10 Aug 2016 at 1:04pm |
Bodnarboy
Posted: 01 Jun 2016 at 12:09pm |
I have all my head studs in and oil pump put back together. Anybody know what nuts I need for head studs? I would naturally go grade 8, do I use lock or regular washers?
Thanks, Billy |
dawntreader74
Posted: 31 May 2016 at 9:22pm |
GOOD-LUCK '' i want to see you ride that WC marv'
littlemarv
Joined: 10 Jun 2013 Location: Wisconsin Points: 1834 |
Posted: 31 May 2016 at 2:38pm |
Yeah, I thought so too. The rest of my life keeps getting in the way. This weekend the tractor rolls in the shed and then I will get more done. The radiator is at the shop and I have to get the mag up to snuff, and clean out a fuel tank, and then it should be just nuts and bolts. (Famous last words).
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
dawntreader74
Posted: 30 May 2016 at 11:24pm |
marv'' i thought you would be driving that wc- around the yard by now' i want to see you ride it
allischalmerguy
Joined: 11 Sep 2009 Location: Deep River, IA Points: 2895 |
Posted: 30 May 2016 at 9:28am |
Marv,
You are such an improvisor! That engine hoist is unreal! Mike |
Allis dave
Posted: 23 May 2016 at 6:18am |
Bodnarboy,
Welcome to the forum and good luck with that motor! The video form Don is the oil pan install video in the knowledgebase section. WC's and WD's originally had shim in the mains and rods. WD45's had no rod shims. You should always check your tolerances with a plastigauge no matter what we tell you. You never know what was done to this motor before you had it. |
Bodnarboy
Posted: 20 May 2016 at 12:20pm |
Hey everybody!!
I am ALMOST ready to assemble my WC that was my grandfather's. Got it back in family in Oct. after 30 some years for FREE!! Sad thing was, #2 had bent rod as it appears to have filled with water and I assuming ppl who had it before I got it back tried to tow start and bent the rod terrible!! So..after the Tisco kit and machine shop work on head and turned the crank, I am ready for assembly, you post on here is AMAZING!! I was wondering you mentioned "Videos from Don" Is that on the site here somewhere? PS. crank was turned .030 on mains, .020 on rods, I bought a set of wd45 rods, have all matching bearings, I bought the laminate pack of shims for mains, as I was told the rods won't need them? what is the correct process for installing the shims? Thanks in advance!! Billy Bodnar Denton, Maryland. |
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8647 |
Posted: 13 May 2016 at 8:32pm |
Marv,
That's looking very good! The WC will be up and going soon at this pace and new parts too! Your rounding the corner when you start getting things painted. Regards, Chris |
allischalmerguy
Posted: 13 May 2016 at 8:09pm |
Great job!
littlemarv
Posted: 13 May 2016 at 9:26am |
Better than Christmas! Got a present from Rick. Should be everything I need to set the engine into the chassis. Pilot bearing, throwout bearing, clutch disk, and water pump. I already have a pressure plate, and a trans input seal, which is just a piece of cork. I think that's everything I need.....
![]() Strung a chain out back for my hoist, ![]() And applied an amount of primer comparable to what was used on the Titanic. Not too worried about looks at this point, just trying to cover up all the bare metal. ![]() ![]() Got the manifold primed and painted with high temp paint. ![]() I've never installed a manifold on one of these engines. I'm assuming the two gaskets on the left are for a 45 or something, and are not used in my application. How do the gaskets go? My best guess is the paper gasket goes in the metal piece, then that goes on the manifold, and the metal pieces are steel on steel to the head? Made some carb mounting studs.
Edited by littlemarv - 02 Sep 2017 at 9:33pm |
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6117 |
Posted: 06 May 2016 at 11:59am |
Actually, BOTH gasoline and distillate fuels (kerosene) get exhaust heat... Kerosene, however, gets more, because of two reasons: 1) Kerosene's flashpoint is much higher than gasoline 2) Kerosene's burn temperature us much lower than gasoline Because of the presence of high velocity airflow through the venturi, there is a pressure drop, and commensurate lowering of temperature in the intake manifold. It's a natural result of Combined Gas Law... air is going from ambient pressure and temp, to substantially lower pressure, thus, temperature. The end result is that moisture IN the air becomes frost, and will rapidly fill up the interior of the intake if additional heat isn't added. SINCE distillate fuel's exhaust temp is lower, it takes more heat at the manifold. Go out early in the morning, start her up, and get it up to half throttle and watch what happens to the intake, and you'll immediately understand. The K-model has pathways for more exhaust heat to be directed to the intake, just for these reasons. NOW... Notice that in this manifold, you've got a HOT side of the casting, and a COLD side. IF you EVER have an engine that acts like it has a vacuum leak, but you cannot FIND it by any of the usual tricks, there's a good possibility that the vacuum leak is from the exhaust chamber, through a crack in the casting, to the intake side. It is also not unusual for a leak in this area to be totally variable... like, sealed up tight when the temp is cold, and really leaky when warm, the crack is opening up as the casting warms up. Very few people check this, and understandably so... it's not an easy thing to fix... oftentimes, guys just change the manifold. BTW, awesome thread- great pictures! |
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 06 May 2016 at 7:01am |
Something I do is that on any exhaust and the four on that plate, I use stainless nuts and lock washers. They don't rust in place as bad, which can give you headache. Leon R Cmo
Sugarmaker
Posted: 03 May 2016 at 7:28pm |
Very nice documentation on your engine build! Thanks for posting the details.
Regards, Chris |
littlemarv
Posted: 03 May 2016 at 3:13pm |
I went with the no thermostat one for a couple reasons. First off, I have three thermostat housings, three of which became perforated when I tried to clean them up. Second, I'm not sure how many combinations of water manifold-head thickness-radiator necks there are. But I think this is original? Not sure, we will see once I get the motor in and radiator set down. I may have to change something.
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 03 May 2016 at 9:46am |
Doing a great job documenting this project. Curious why you opted to stay with the old style water outlet instead of the later with thermostat for automatic temp control.
KenBWisc
Joined: 15 Sep 2009 Location: Fall Creek, WI Points: 1186 |
Posted: 03 May 2016 at 8:43am |
I don't understand why the pics of your rolling chassis don't appear here as they did in an E-mail notification I received. But,,, in relation to steering wheel slop; find the bearing adjusting bolt under the pedestal and between the two front wheels. Tighten this a bit at a time while checking for reduced slop. It may take care of it for you.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
B26240
Posted: 02 May 2016 at 6:16am |
Less dramatic than I thought the trip up the stairs would be, all I can say is you and your brother must be some "heavy duty guys". My fear would be getting it up to stair number four and running out of gas. Mark
littlemarv
Posted: 01 May 2016 at 8:44pm |
Time to get the motor outside. I had to take the valve cover back off, because now that I put the pan and stands on, its too tall. Put a piece of pipe up in the floor joists to hang my hoist from. Big brother stopped by, and we lifted the engine and ever so gently slid it off the bench. Set the two wheeled cart under it and lowered it down.
![]() Ratchet strapped it to the cart, and up the stairs we went. He was pulling, and I would lift up each step, and it really went pretty good. Didn't have a photographer when we really needed it, and our hands were definitely full! But here it is rolling out the kitchen door... ![]() So there, a successful trip out. Needs to go out to the paint booth for a coat of primer. Then the chassis needs to come into the garage and we can set her home. ![]() Edited by littlemarv - 02 Sep 2017 at 9:28pm |
cdweirrick
Joined: 19 Apr 2016 Location: Mercer Co, OH Points: 41 |
Posted: 30 Apr 2016 at 3:26pm |
I have loved reading this thread. As someone who is new to all of this and looking forward to learning, it has been full of valuable information. I cant wait to see the finished product!
Grandpa's 1950 WD
1950 G |
BenGiBoy
Joined: 11 Nov 2015 Location: Ashville, NY Points: 705 |
Posted: 30 Apr 2016 at 12:05pm |
K stands for Kerosene probably.
'39 Model B
Tractors are cheaper than girls, remember that! |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8946 |
Posted: 29 Apr 2016 at 10:35pm |
Yes it does.the K cover is made so the exhaust heats the intake pipe which doesn't work so good for gasoline.
littlemarv
Posted: 29 Apr 2016 at 10:26pm |
When I got the manifold back, they had taken the cover off and cleaned it out. I never thought to look closely, I just thought "Huh, looks like I need to get some exhaust gasket paper and make one for this, so the intake and exhaust gases don't mix."
So, I picked up a sheet of exhaust gasket paper. Boy is that some crap to work with. It has metal in it so custom trimming is pretty tough. At any rate, now that I look at it, that upper chamber does nothing. I thought that was the intake side of the manifold, but it is more or less a sealed chamber. Nothing goes in and out of it as far as I can tell. Whats it even for? Does that have something to do with the "G" or "K" covers you can get? ![]() Anyways, made a gasket and installed the cover with some new brass nuts. Masked off the carb surface, out to the paint booth tomorrow, for some extra high temp primer and paint. I don't know how hot the old manifold will get, but I figure the stuff rated for 3000 degrees ought to cover it. (Yeah right) ![]() Edited by littlemarv - 02 Sep 2017 at 9:27pm |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4264 |
Posted: 25 Apr 2016 at 10:14am |
When I rebuilt the engine for my 45 I had to use a WD block. Learning how to safety wire was one of the more interesting parts of the job.
BenGiBoy
Posted: 25 Apr 2016 at 7:16am |
Lookin' real good, by the way. It is fun to watch your progress!!
'39 Model B
BenGiBoy
Posted: 25 Apr 2016 at 7:15am |
Definitely some pictures of 'the trip out'!
'39 Model B
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 24 Apr 2016 at 8:16am |
She is looking good, I'm happy to see you rewired the main cap bolts. I have built lots of engine stands so the engine can ship and you have a nice set built. Now it's time to move her out of the house and please post some shots of it going up the steps and out the door. lol
littlemarv
Posted: 24 Apr 2016 at 1:02am |
Flipped the engine over.
![]() ![]() I thought the safety wire videos were really neat, so I redid those. ![]() ![]() ![]() Installed the oil pump. Yes, that is Don's oil pan video in the background. ![]() Put the pan on, torqued the bolts to 18 foot pounds. ![]() Flipped it back up, put the valve cover on just snug, and installed these stands I welded up out of some scrap iron I had laying around. ![]() ![]() So there it is. I think I will put the water pump on, then up the stairs she goes, out to the garage for a coat of primer. Thanks for looking! Edited by littlemarv - 02 Sep 2017 at 9:18pm |
TomMN
Joined: 13 Sep 2009 Location: Elbow Lake, MN Points: 858 |
Posted: 11 Apr 2016 at 9:08am |
Very nice. I have only seen the oil flowing up top with the engine running and the cover off. Fun to see it in a steady state as the oil flows through where the designers intended.
Page <1234> |
