201 4 inch sleeves
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Topic: 201 4 inch sleeves
    Posted: 21 Jan 2010 at 5:52pm
I need four worn out 4 inch sleeves that are in tack no junks broke out of them . My 321  cubic inch pieces that I have priced are going to be assemble and put into a lerio tractair just to blow the minds of some tech officials when they cant figure out the rpms it suppose to run for a pull or two. pistons due to being run for several years are a llittle undersized for a new 4 1/8 sleeve.  any help is appreciated in advance.
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 8:28pm
hey mitch,i have a wc cracked block with 4"sleeves in it .if you want to drive all the way to minnesota,iwill give it to you!lol-mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 8:44pm
thanks i will keep them in mind.
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 10:22pm
i have a set of 4 real nice shape  but im up in ontario canada
if farming was easy everybody would be doing it
DocsEquipment,IL. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DocsEquipment,IL. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 9:02am
i should have a few 309-246-2900 Doc
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 11:05am
I have 4 in OH
