2000 mono frame plow.
CCF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CCF Quote  Post ReplyReply Direct Link To This Post Topic: 2000 mono frame plow.
    Posted: 02 Dec 2023 at 4:36pm
Just bought a 2000 5 bottom hydraulic reset plow have a few questions I will be going through it this winter anything in particular to watch for seems tight everywhere I could wiggle.
1. What is difference between 386 and 387 bottoms
2. Are they interchangeable
3. Are other parts for these available if needed?
Thanks for info
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2023 at 7:53pm
I think the 387 bottom  is the only one with  parts available, as for plow parts themselves, I don't know.  I have 2 of the 2000 plows but mine are just the trip beam.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2023 at 9:57pm
This is going back a long way - but I THINK the 386 was the short wing high angle moldboard that, if set properly, would leave the field level without seeing a single plow ridge - the 387 was the long wing and would leave the distinctive ridge of every moldboard - they were for different type soils. They used the same shares - 14"-16"-18" in std and economy and deep suck style plow shares. I don't think many parts are available - Herschel used to have a chart of AC plow parts.  ( I remember at the LaPorte plant seeing them polish the moldboards by hand - mounted on a long wooden handle and mating to a large grinding/polishing wheel one at a time) .  Many moons ago the Dealer in 60's would demonstrate 190XT's and out plow everyone with a 5-16 semi-mount before the Monoframe. He put 14" blades on the 16" 386 bottom and found the draft load a gear less.  Worked in our soils.  On the other hand some used 18" on a 16" to be able to leave the desired results.  Lots of plow stories...
Edited by tbran - 02 Dec 2023 at 10:05pm
