2000 GMC electric motor keeps running
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: 2000 GMC electric motor keeps running
    Posted: 21 Jun 2019 at 5:00pm
My truck has an electric motor that keeps running. It bolts to the frame left of the transfer case. It looks like brake lines going to it.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2019 at 5:20pm
If that is brake or ABS related have you checked the brake fluid level?
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2019 at 8:16pm
Steve M Ind View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M Ind Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2019 at 8:52am
The relay is built into the ABS box. The relay is stuck on and needs replaced or it will run the battery down. Need to replace the controller part of the box. Have seen this many times.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2019 at 10:48pm
My '99 Chevy had same thing happen, but the ABS pump kicked on, blew the rear brake line out, and totally emptied the master cylinder...
At 45mph...
With a flatbed trailer in tow...
with 4600lbs of lumber on it...
...heading for a stop sign....
at a 2-way intersection...
... with two tractor-trailers full of grain coming one direction
...and a five-axle dumptruck full of gravel coming the other way...
I was fortunate to have presence of mind to slap the trans into LOW, then grab the trailer brake controller and squeeze it to full, while flipping the GAIN switch to max...
I got stopped about two feet into the intersection... all three drivers saw my trailer tires smoking and knew what was up... they moved over JUST ENOUGH to keep me alive.
Cost of replacing that ABS pump (after lifting off the cab) was seriously in excess of the value of the truck, so away it went.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2019 at 5:03am
 Hey Dave Kamp,,,glad to see you safely back home from the Great Southwest snake country,,,,,WinkWink
 Dang,,that sounds like you had you a close call,,!! You know,,them vehicles always seem to gain speed when them brakes fail don't they,,,?? There may be one of them trks up for sale up around the Eurica Springs area,,,,,,Wink,,Chit,,I'm outa here,,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2019 at 5:16am
I checked the fluid and it was ok. I drove it around the place and the brakes work fine with it unplugged. I haven’t had much time to mess with it.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M Ind Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2019 at 8:13am
You can unplug it or just pull a fuse, Will not have the ABS function but will have normal brakes and the pedal should feel normal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2019 at 10:25am
Is it safe to drive to work? They feel fine.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M Ind Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2019 at 3:16pm
Some of my customers never fix them. Just drivem with the ABS light on.
This page was generated in 0.520 seconds.
