200 tach
clarkscreek View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote clarkscreek Quote  Post ReplyReply Direct Link To This Post Topic: 200 tach
    Posted: 05 May 2018 at 4:05pm
I was trying to get my taxh working on my 200. Ordered alt with taxh drive and found out when I received it it had wrong gears. It had 14 and 43 so I switched out to the 12 45. Pull that came on alt was wrong size 3 5/8 instead of 3. No big deal just switched with my old one. New cable. Hooked it all up and found out old tach was junk, so I ordered a new one. Hooked up everything and it read way too fast. Like 2500 when I was at 2000. So I switched to the bigger pull and I'm still running right at 200 rpms too fast. What's going on?????
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2018 at 4:22pm
I am going through the same thing did you get the alternator from Kingsport Tenn? I was going to call them Monday and see what they sayI have counted the same teeth you have. I feel like it is right at idle but wide open it will bury the tach.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote clarkscreek Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2018 at 4:44pm
No I got it from the m yesterday's tractor. I'm thinking of putting on a pulley of 4 1/8 diameter and that should make it right. It just doesn't make sense to run a pulley 1 inch bigger to read right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2018 at 4:46pm
The 14/43 is a 3.07 to 1 ratio........the 12/45 is 3.75 to 1 ratio which is the slower of the two gear sets.  The 3 5/8" pulley would be about 17% slower than the 3 inch pulley.
