200 tach drive
clarkscreek View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote clarkscreek Quote  Post ReplyReply Direct Link To This Post Topic: 200 tach drive
    Posted: 17 Feb 2018 at 7:04pm
The 200 I bought a year ago had a new 3 wire Delco alternator but no drive or cable. Can I put a tach drive on it just by pulling plug out of back of alternator. If so where's a good place to get the drive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2018 at 8:19pm
What you see as a plug is probably the needle bearing with a bottom to it. Besides, the shaft won't have a threaded hole in the end of it to accept the threaded in drive gear. So the answer is no.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote clarkscreek Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2018 at 8:28pm
Thanks, so I'll have to buy alternator with the tach drive then. Oh well my other tractors take the same alternator so I can just put it on the shelf till one goes down. Where is the best place to get a good alternator with the tach drive.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 9:37am
I have a used working alternator with the tach drive in it. Was on a 190xt. You would have to take the dual pulley off of your alternator and put it on this one.   190xt only had a single fan belt
Edited by HagerAC - 18 Feb 2018 at 11:54am
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2018 at 9:26am
Which Delco 3 wire alternator? External or internal regulator? The original used an external regulator. My 200 has an internal regulator alternator modified for the tack drive.
This page was generated in 0.088 seconds.
