200 seat |
acplowboy45
Joined: 09 May 2013 Location: connersville IN Points: 264 |
Topic: 200 seatPosted: 20 Jan 2019 at 7:15am |
What seat did the 200's have on them the 3 piece seat or the black seat with the flip up arms. Where the best place to get one.
Posted: 20 Jan 2019 at 7:27am |
They used two different black seats. What age or serial number is the tractor ??
acplowboy45
Posted: 20 Jan 2019 at 11:33am |
It's a 1975
DougG
Posted: 20 Jan 2019 at 12:17pm |
Tractor Supply has got some nice ones
HD6GTOM
Posted: 20 Jan 2019 at 1:38pm |
My late one has the black seat with the flip ups.
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 20 Jan 2019 at 6:23pm |
My '75 has the black with flip up arm rests.
Wink I am a Russian Bot |
Mikez
Posted: 20 Jan 2019 at 8:44pm |
How much do you want to spend. A fellow forum member tipped me off to a seat that's made for logging equipment and is almost identical to the original
JWV Fulton
Joined: 19 Mar 2017 Location: Fulton, MO Points: 24 |
Posted: 22 Jan 2019 at 9:09am |
Go to www.tractorseats.com and you should find what you need.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5180 |
Posted: 22 Jan 2019 at 1:03pm |
They have a lot of nice seats that are a lot like the original, but not quite... Edited by WF owner - 22 Jan 2019 at 1:05pm |
KJCHRIS
Posted: 22 Jan 2019 at 11:09pm |
IF memory is good today; the early black seats are the ones where the arm rests attach to a stud sticking out each side of the back rest. Later seats have a bracket for the arm rests that bolts (using 2 of 5/16" bolts) to the irons coming up to hold back rest.
Arm rests are the same for both seats. AGCO has them in the Heritage Parts catalog. Backs n seats are available thru most ( several on this site) vendors dealing in seats. If you need to redo the suspension DJ's has most of what you need, have the lever/arm now, also the pins and bushings, the 4 plastic wheels for the slide are getting hard to find.
dansig1
Posted: 21 Feb 2019 at 10:08am |
Can you tell me where I can get this seat and how much? Thanks. I'm referring to Mikez post.
Edited by dansig1 - 21 Feb 2019 at 10:09am |
Leadoff
Posted: 21 Feb 2019 at 4:45pm |
Dansig1, Serco Loaders, a supplier of forestry industry equipment, uses the seats on their loaders. Their dealers carry replacement seats. Check the Internet for your nearest dealer for availability/price. I purchased a seat for my 1975 185 several years ago. As far as I'm concerned, the seat is an exact match to the factory issue from Allis Chalmers in appearance, quality, dimensions and comfort etc. Milsco (Milwaukee Seat Co) supplies the seat to Serco, and AC back in the mid/late 1970's. Pictures, discussion, more information etc are available in an earlier thread started by Forum Member MikeZ on April 21, 2017, title Seat in 200 Good luck with your project |
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
WF owner
Posted: 25 Feb 2019 at 7:12pm |
I just got an email from DJ's and they have this seat. I'm sure it's not the same as original, but that's what the are listing for it.
dansig1
Posted: 27 Feb 2019 at 3:07pm |
Thanks for the replies! Now I am wondering if a 200 seat will bolt onto a 190xt suspension or do I need to get the 200 suspension? Will the 200 suspension bolt to the 190xt fuel tank?
Leadoff
Posted: 27 Feb 2019 at 6:20pm |
Dansig1
From the online AGCO Parts Book the 190 (page 192) and 200 (page 132) have common seat assembly support connections to the fuel tank for older serial number tractors (part no 70241895 - seat support). Later serial no 200 tractors (page 134) had a newer seat assembly setup. The assembly shown on page 134 for the 200 is what is required to support the Milsco seat noted in my earlier post. The year/serial no of your 200 should help you determine what seat will fit your tractor. Also, based on the common part/attachment to the fuel tank for the seat assembly for the older 190/200 models noted above, there is probably a way you can mount the Milsco seat on a 190 with a few seat support/suspension components from a donor 200. Hope this helps
