200 seat rebuild ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: 200 seat rebuild ???
    Posted: 01 Apr 2019 at 11:12pm
Hi everyone have question.
Have suspension out going to do pins and bushings. Should I have shock rebuilt or is there anyone that does that. It seemed ok just pins an bushings are wore. Thanks
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2019 at 7:08am
I don't think you can rebuild the shock, can you? The only thing replaceable are the rubber bushings at each end if it uses rubber bushings.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2019 at 9:07am
Yea I wasn't sure on the shock. That why I figured I'd ask
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2019 at 9:15am
If I went to the trouble of tightening everything up, I'd sure hate to have a dead shock absorber. It would be like riding a jack-in-the-box.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2019 at 6:29pm
From experience, IF you weigh 200 lbs or more and the OEM shock / spring assy is shot it just bottoms out and rides almost as poorly as before replacing worn pins n bushings, cushions n arm rests. Shock was on order but needed to use tractor, now with the new shock/spring installed it rides really nice, should've rebuilt it 10 years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2019 at 10:32pm
Hmm so your saying I should buy a new shock to
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2019 at 6:11am
I would. I bought a new shock years ago for my WD when  I went through that seat assembly and it rides pretty nice for a WD.
Edited by Lonn - 04 Apr 2019 at 6:11am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 1:23pm
Well I added it to my order. Be like a new tractor lol I hope anyways
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2019 at 11:06pm
Got all parts in. FYI the shock comes with the spring and the rubber bushings an spacers on each end. Now I have extras.
fourthgeneration View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 7:37am
Did the shock come from AGCO or aftermarket?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 8:22am
Yes agco, got all pins, bushings and shock from agco. I'll take picture
Edited by Mikez - 20 Apr 2019 at 8:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 9:08am
What did the shock cost? I bought the pins from AGCO and bronze bearings at the hardware store.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 11:08am
It was $177
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2019 at 10:37am
Thanks Mike.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2019 at 2:30pm
Stupid question
When I put it back together should I put a bit of white grease, or never seize or some kinda oil on the pins. In my mind I want to put something lol
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2019 at 3:52pm
Anything would be better than nothing. Bronze bushings will soak up oil to a degree.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2019 at 4:54pm
On my 200 and D17 I have kept every pivot on the seats lubed with cheap motor oil and there is very little wear on either one. Not bad for a 56 and 45 year old tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2019 at 6:10pm
Took some pictures
Wish the rest of tractor looked as good as seat.
Edited by Mikez - 23 May 2019 at 6:15pm
Leadoff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2019 at 8:29pm
Mikez,
Your new seat and support assembly looks great.  Congrats on taking the time to maintain the original appearance and functionality of your 200 tractor.
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2019 at 11:26pm
Thank you again Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2019 at 9:43pm
It works good. Harder for me to transfer over to it lol. But worth it.
acnh210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acnh210 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2019 at 8:30am
Mike, where did you purchase the seat itself at?
Terra Tiger, WD, 7040ps, 8050 with westendorf loader, 8050ps fwa.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2019 at 5:29pm
A fellow forum member gave me info at the time. You google Serco loaders. It's a forestry log loader and they use that seat. When you look it up find your local dealer. I be leave this is the part number. SERHH1005 and SERHH1106. I had the parts guy send pictures to be sure. It's a nice built seat but not cheap. Good luck
This page was generated in 0.091 seconds.
