200 questions
Tenn allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tenn allis Quote  Post ReplyReply Direct Link To This Post Topic: 200 questions
    Posted: 24 Nov 2016 at 8:24pm
May have a chance to buy a 200 allis my dad bought new in early 70's wondering if you could add the 1000/540 pro shaft to it was a 540 originally doesn't have hydraulic pto just the big lever to the left of the seat
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 8:50pm
Sure, it can be done, but might be more expensive than you think. You've got to buy a complete lift arm housing with the dual-speed shaft for starters. After that, you'll have to drop off the PTO clutch box and swap out the two internal gears, and those might be hard to find for your manual PTO set-up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tenn allis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 9:04pm
Did they make dual pto without the hydraulic engagement I know on the hydraulic ones they still have the coupler in the pd housing
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 9:17pm
I think it was probably only offered as the 540/1000 hydraulic clutch style. But, that only means you need to find the 1000 RPM gears for a non-clutch PTO up in the PTO clutch box to make it work. All 540/1000 units are 1000 RPM on the front end of things.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tenn allis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 9:19pm
Any recommendations on a good salvage yard that might have what I would need
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2016 at 6:23am
I have a 540/1000 lift arm housing for $400, but we are 600 miles apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tenn allis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2016 at 6:59am
If I get my hands on it we'll get in touch
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2016 at 10:33am
They did make it with a manual 540/1000 l had one here. We parted it out. Sold the 540/1000 to Leon B. He is on this website a lot.
This page was generated in 0.191 seconds.
