200 pto
mike-mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike-mn Quote  Post ReplyReply Direct Link To This Post Topic: 200 pto
    Posted: 16 Jul 2021 at 8:18am
Last summer I had the coupler for the  hydraulic pto inside my 200 disengage.  It did it again this summer, both times baling hay, but different balers.  I took the plate off like Dr. Allis said and slid the coupler forward.  I'm pretty sure I heard it click in place.  Is there something else to look for or do when I go in there again?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 9:11am
There were two types of sliding coupler systems. I assume yours does NOT have the short lever directly behind the battery box ?? If this is true, there must be a problem with the snap-ring that is inside the coupler keeping it locked where it belongs. It shouldn't slide out of engagement by itself. Twisted splines on the rear shaft or a weak snap-ring ??   I've only had a couple of tractors ever do this in the last 4 decades and each one I made sure it could never happen again, by reaching in thru the side and strategically placing a couple spots of weld on the front shaft so the coupler cannot slide forward. Crude? yes. Fixed ? YES.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike-mn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 9:44am
I was thinking of doing something like that, but was not sure if there was something else first.  It is very irritating, and I don't want to do it again.  Thanks again.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 11:25am
Make sure the back shaft does not have play in and out
This page was generated in 0.120 seconds.
