200 PTO seal
clarkscreek View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote clarkscreek Quote  Post ReplyReply Direct Link To This Post Topic: 200 PTO seal
    Posted: 13 Jun 2017 at 12:29pm
Hey guys the old 200 started leaking around the pto. It is the two speed and in another post it said something about holding a shaft in when you take the lift housing off. I was wondering if someone could explain the procedure a little better for me thanks.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2017 at 10:40pm
If shaft comes out with rear housing it will drain the PD housing. Best to drain PD before you start.    MACK
