200 PTO seal |
clarkscreek ![]() Bronze Level Access ![]() Joined: 04 Mar 2017 Location: kentucky Points: 137 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Jun 2017 at 12:29pm |
Hey guys the old 200 started leaking around the pto. It is the two speed and in another post it said something about holding a shaft in when you take the lift housing off. I was wondering if someone could explain the procedure a little better for me thanks.
If shaft comes out with rear housing it will drain the PD housing. Best to drain PD before you start. MACK
