200 Power director
Jim seIl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim seIl Quote  Post ReplyReply Direct Link To This Post Topic: 200 Power director
    Posted: 09 Feb 2011 at 7:49pm
 freind just bought a 200 and high side does nothing ( not even a quiver) low and net are fine does 200 have hyd  lines inside for pd seams like 30 years ago on 180 I replaced a line in there any suggestions? thanks Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 8:36pm
Attach a gauge to the valves test ports and measure the pressure in "Low" and then in "High"..........if you got zero in high, then you can proceed looking for a leak by removing the valve and cover and air checking it.
