200 on 18.4 x 34 to 18.4 x 38
72AC200 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72AC200 Quote  Post ReplyReply Direct Link To This Post Topic: 200 on 18.4 x 34 to 18.4 x 38
    Posted: 09 Aug 2021 at 5:47pm
I have been thinking about switching my 200 to 18.4x38. I have 18.4x34 on right now and I have been wondering how to do that ?
Darb210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2021 at 6:50pm
unverferth mfg makes a step-up rim that will use your 34" cast centers, i think that would be the easiest way
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2021 at 7:05pm
+ 1 on the step up rims. I did a few with them when I owned the tire shop. Make sure you double check all the bolts holding the wheels on. Run them no more than 1 hour and check. If you hear any snapping or popping stop and check them.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2021 at 8:06pm
We did the step up rims on an IH 856. Best thing we ever did for that tractor.
Sat more level, could plow in the same gear as the other 856, better traction
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2021 at 9:30pm
The standard tire on a 200 is 18.4-38. 190's had 18.4-34 standard. They have different final drive ratios. Get the 200 wheel centers.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2021 at 9:51pm
If you want spin-outs then you need 38" centers and rims. Didn't they also make extended blocks to switch from 34s to 38s?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2021 at 7:16am
200's never had 18.4 38's as standard equipment, altho near the end most had them. Most of the early 200's had 34 inch rear rubber. Actual gearing/gear ratios between a 190XT and a 200 are exactly the same except for 1st gear, which is slower on a 200. A 200 had a different ring and pinion (more strength/wear life) but the ratio was the same. Same goes for the final drives....wider stronger gears, but the exact same ratio.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2021 at 4:24pm
Yeah ive seen alot more 18.4-34,s on 200,s than 38,s - not standard at all
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2021 at 5:14pm
In all honesty, for a 200 to nicely replace a 190XT, it should have had 18.4 x 38 inch rubber.  It was about a 10% speed up for each given gear selection, more weight and traction.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2021 at 12:54am
Do you have spin outs or std rims?
The std rims you can get adapter type wedges ( unverferth ) to go from 34" to 38" then just need 38" rims and tires.
Spin outs, you need different cast wheel center, rims and tires.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2021 at 5:07am
A few years ago I looked at a 200 with 20.8 x 38”, didn’t run it though. Ours has 18.4 x 38” and is still plenty slow. Just a thought if you are changing out.
