200 Injector lower copper sealing washers |
Bruce Nelson
Joined: 17 Sep 2009 Location: Centuria, WI Points: 137 |
Topic: 200 Injector lower copper sealing washersPosted: 12 Jun 2023 at 12:04pm |
What works to remove the lower injector sealing washers. I removed the injectors and 3 washers stayed in the head.
DougG
Posted: 12 Jun 2023 at 6:06pm |
A 5/8 tap, used to clean out bolt hole threads- get it down in there and turn it a few times then should pull out
KJCHRIS
Posted: 13 Jun 2023 at 12:08am |
I've used a drill bit larger than hole for tip. Tap into washer and turn with a plier while pushing down.
