200 hydraulics
mike-mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike-mn Quote  Post ReplyReply Direct Link To This Post Topic: 200 hydraulics
    Posted: 23 Oct 2020 at 2:33pm
My  200 has hydraulic pto.  It quit working while baling this summer.  It was not steering as easy as before either.  It never chattered.  I changed the filter and was going use it to rake after that.  It then blew front cooler or hose and sprayed oil all over.  Would there be circulation problems or am I just lucky?  I have not looked at the cooler yet, since it is still sitting in the field.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2020 at 2:38pm
Coolers are known for failing, as they are in the steering circuit. So whenever a driver cranks the steering wheel completely left or right and HOLDS it there while making a turn, that cooler has 1600 psi of pressure inside of it until the wheels are back to normal.
