200 Hydraulic Question
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: 200 Hydraulic Question
    Posted: 17 Jun 2019 at 8:07pm
1st open or closed center hydraulic and is that the same as the 7000 and 8000 series?
 2nd I can get oil out of the 3 point by tying into a lift cylinder, but where would it get returned.
  I am thinking about using it to pull a small sprayer around the fence lines. I would like to use the remotes to lift and lower the booms and swing them in and out. I want to run a spray pump with the hydraulics from the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2019 at 7:22am
OPEN CENTER and not like anything other than a 7000, not 7010 & up. You could use the 3-point lever (and return to sump) to run your sprayer pump, yes.  BUT, when the pump is running you will not be able to lift either boom. You'll have to shut off the pump, position your booms where you want them and then turn the pump back on.
Edited by DrAllis - 18 Jun 2019 at 7:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2019 at 8:11am
I was hoping you might see this, DrAllis. Now where might one find a sump return port? Is it in the rear end or in the transmission? I see what looks like a plug in the rear end casting just to the left of the PTO and lower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2019 at 8:13am
NO !! You'll have to return it to the hydraulic fill/dipstick hole or the drain plug underneath the torque tube.
