200 hydraulic pump.
clarkscreek View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote clarkscreek Quote  Post ReplyReply Direct Link To This Post Topic: 200 hydraulic pump.
    Posted: 22 Sep 2022 at 5:35pm
Was subsoiling some ground when I started getting sprayed with hydraulic oil. Shut tractor off to check and found the rear housing of the hydraulic pump cracked. All functions are working perfectly before and after. Is this a common problem or is something deeper going on? Also can I get just the rear section?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2022 at 7:32pm
What’s the sr number
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote clarkscreek Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2022 at 7:42pm
8818
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2022 at 9:19pm
I have a used pump that I would check out and if it is a good pump I would rebuild and sell. If pump is not a rebuilder I would sell the rear housing providing it was good. Please call after 5PM  or text anytime Albert  660 541 2029
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2022 at 8:35am
Be sure to check relief pressure before busting another hsg. Only thing I know that would crack hsg.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote clarkscreek Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2022 at 8:43am
So after taking the pump off I found where the previous owner had jb welded along the crack on the back side. This cracked extends from the secondary to primary ports. Only pressure I have ever checked on tractor was remote pressure, and that's only because my trail mower uses hydraulic pressure to float the cutter bar. That pressure was right at 1950 to 2000. When I get it back together how do I go about checking and adjusting relief pressure?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2022 at 9:30am
This trail mower requires you to lock-in a remote lever and maintain a constant 2,000 psi of pressure to it ?? That won't work on a 200.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote clarkscreek Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2022 at 9:56am
No that's just to charge system on mower. After that while your running its just up down like normal.
