200 hydraulic issue
K bockting View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K bockting Quote  Post ReplyReply Direct Link To This Post Topic: 200 hydraulic issue
    Posted: 14 Jun 2021 at 4:10pm
Lost steering and pressure to power director will move when idled up.
2300 psi at remote. Have had issues with flow divider sticking. Has hydraulic pto any ideas? Thanks
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2021 at 9:20pm
Most likely the flow divider.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2021 at 8:18am
There is one big pump that satisfies the power steering/power director/pto circuit (priority) and then the hitch lift/remote circuit. If you have good pressure/flow at the remotes, it has to be related to the flow divider spool somehow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote K bockting Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2021 at 10:37am
Yes flow divider sticks. Any recommendations?
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2021 at 11:09am
Take out  the flow divider spool and polish the bejeezuz out of it.  Make sure there is nothing causing it to stick, like a tiny spec of dirt or chunk of o-ring or such in its passage
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2021 at 12:19pm
Might be time to drop the sump and clean/inspect the suction screen and change the hyd oil and filter. Polish that spool with emery cloth and clean the bore until the spool is free to slide.
Post Options Post Options   Thanks (0) Thanks(0)   Quote K bockting Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2021 at 6:43pm
Thanks for the replies.
Just had split for pd rebuild all new oil and filter. Been an on and off again issue. Probly crud in system
Got it going for now
