200 Hyd pump
LeakyBoot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeakyBoot Quote  Post ReplyReply Direct Link To This Post Topic: 200 Hyd pump
    Posted: 19 Jul 2017 at 4:27am
0
Edited by LeakyBoot - 20 Jul 2017 at 4:24am
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2017 at 6:54am
Don't know where or how you checked the pressure, but I would adjust relief valve before removing pump.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeakyBoot Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2017 at 11:12am
0
Edited by LeakyBoot - 20 Jul 2017 at 4:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2017 at 12:22pm
Adjust it anyway....pump on my 220 had been run in need of wear plates/backup seals too long and fluid leaking by had eroded a passage where the backup seal sets and made it "unfixable".Pull yours apart and see what you have.Go from there.Double check system pressure after installing new/different pump.I had cranked my relief up for worn pump and forgot to change after new pump.Several hours use later it split the housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2017 at 12:25pm
Always re-seal the main relief valve first and do NOT change the adjustment screw. If pressure still low, adjust screw inward (and count the turns) to see what happens. If that doesn't work, return screw to original setting and go thru pump.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2017 at 3:01pm
The gage on the baler is only the belt tension and depends on the relief valve setting of the baler. The tractor pressure should be checked at the remotes. The tractor relief valve is on the control valve and not the pump.
This page was generated in 0.049 seconds.
