200 Battery Box Needed
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Topic: 200 Battery Box Needed
    Posted: 03 May 2023 at 10:37pm
Looking for a battery box for a 200, need the bottom piece, thanks
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2023 at 8:34am
 If you don't find one and can make a drawing I can probably make one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2023 at 4:59pm
A battery box from any 190/190XT should be the same.
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2023 at 9:32am
Gary(VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2023 at 10:35am
How bad is yours? I have one from my 190 that I was going to replace with one from a Parts tractor I bought that's a letter better. I haven't swapped them yet but the one I'm taking off is very usable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2023 at 1:22pm
Mine is pretty bad, bad enough I don’t think laying plywood in it will help it last any longer, I changed the battery out the other day and noticed it, I did put the new battery in it so I could start the tractor and let it run but couple trips through the hay fields and it will probably fall out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2023 at 3:58pm
I can try to take some pics of the one on my tractor over the weekend if you want.
It would be easier for me to text them if you can pm me your cell
