200 allis pto |
clarkscreek
Bronze Level Access
Topic: 200 allis ptoPosted: 04 Mar 2017 at 6:48pm |
Just bought my first allis after being a lifelong deere man, needed a 90hp tractor and couldn't bring myself to pay what a decent 4020 brings. My question is, it has hydraulic pto and it stays on. when I move the lever it is moving the valve but I don't feel anything happening, like no notches or anything. is it supposed to feel like this, should I feel the different locations like on and off.
MACK
Posted: 04 Mar 2017 at 9:40pm |
There should be three poisons, on off brake. Pin shears in lever some times. MACK
DanWi
Posted: 04 Mar 2017 at 10:02pm |
The pto will creep in the off position when it is cold and the brake is wore out. Have you tried it warmed up with something hooked to the pto. Shut the tractor off hook up pto and see if it stops then. If it doesn't then a valve problem also at that point see if pto slips or brings pto up to speed as it should when turned on.
clarkscreek
Bronze Level Access
Posted: 05 Mar 2017 at 7:42am |
Thanks guys I'll get it checked out Tuesday.
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8759 |
Posted: 05 Mar 2017 at 8:45am |
Good luck with the 200!!!!!Darrel
Posted: 05 Mar 2017 at 12:43pm |
The console lever itself has 3 detents in it, if working correctly. Ball and spring inside console.
clarkscreek
Bronze Level Access
Posted: 24 Mar 2017 at 11:33pm |
Finally got to work on the tractor. You guys were right ball was missing for the detent. PTO does what it should except for the brake part. It seems to pull pretty good even with it off. It won't start a load off but it will keep one coasting after you turn it off. Will there be less pull when the oil gets warm or will it stay the same.
DanWi
Posted: 25 Mar 2017 at 10:47am |
When the oil is warm it should stop . If I hook up the manure spreader or feed grinder on a cold day I have to turn the tractor off to hook up the pto then when I start the tractor it will turn for a few minutes or when I hook up to the spreader I don't hook up the pto till I fill the spreader, by then it will stop.
DougG
Posted: 25 Mar 2017 at 5:09pm |
They have a BRAKE detention, if the brake pad is good it will stop it and hold,,
