200 allis hydraulic pto problem
gjmac22 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gjmac22 Quote  Post ReplyReply Direct Link To This Post Topic: 200 allis hydraulic pto problem
    Posted: 18 Jun 2023 at 4:44pm
I have a 200 hydraulic controlled pto it spins all the time when there is no load but when it is hooked up to my hay cutter it might work all day it may never work my hydraulic pump is getting weak my lift arms are very slow to raise at high idle but my steering is fine any help is much appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2023 at 5:48pm
Clarify.......The PTO "brake" while connected to the hay cutter might work all day or might not ??  In other words, the PTO clutch always pulls a load just fine ??     The power steering always works well, but the 3-point lift is SLOW even at FULL THROTTLE  ??  Do the hydraulics lift the hay cutter fast ??   Is this a 540/1000 PTO equipped tractor ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote gjmac22 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2023 at 7:41pm
To get the lift arms to move I have to idle the tractor up but the steering is always easy even at low idle and it appears that the pto spins with the pto brake on and when engaged the pto may spin the hay cutter for 10 minutes or all day then just quit without warning and sometimes won’t even spin the hay cutter at all but will always spin when not hooked to anything
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2023 at 8:09pm
To get the lift arms to move up it REQUIRES the engine to be throttled up probably to 1500 or more RPM and the faster the engine runs, the faster it will lift. This is NORMAL and the remote outlets also operate in the same manner.  I asked if the PTO was 540/1000 RPM and you didn't answer.    The PTO lever to the right of the seat has THREE positions: down is OFF with brake.....UP is fully engaged and could kill the engine if loaded heavily........middle is COAST which may spin and pull a very light load.  The fact that the PTO brake may not be working doesn't keep the PTO from pulling a load and performing just fine. There are many that the PTO brake may not work and the tractor is regularly used on PTO jobs. I question whether or not you are fully pulling up on the PTO lever fully OR does the PTO seem to quit turning under a heavy load?? which could mean the foot clutch is slipping.  Does the foot clutch pedal have ANY free-play ?? should be a minimum  of two inches of free-play.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gjmac22 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2023 at 12:24pm
Sorry it is a 540 pto and when the pto is engaged pulling up on the lever it will work under a load for awhile then just stop and the lever seems to still be engaged and the foot clutch seems to working.. if the foot clutch is slipping would the tractor stop pulling or act light it is slipping ?? I’m very new to allis tractors I inherited over 20 of them and I’m trying to keep them in operation
Edited by gjmac22 - 19 Jun 2023 at 12:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2023 at 5:11pm
I don't know what you are capable of, in terms of diagnosis or repair work. Yes, if the foot clutch was slipping, it will affect ground speed, but can you notice it ?? I would. I think to eliminate the foot clutch as a possible issue (it still needs 2 inches of clutch pedal free-play) you need to set both brakes hard. With the engine already warmed up, place the Power Director lever in HIGH range. Now shift the transmission into 8th speed. While holding the clutch pedal down, throttle the engine up to 2,000 RPM+. Let up on the clutch pedal fully and the engine should stall.  Quickly re-start the engine to establish oil pressure for the turbocharger. If this test stalled the engine, the foot clutch isn't your problem. If it doesn't stall the engine, you have a foot clutch problem. Again, I cannot stress enough the importance of 2 inches minimum of clutch pedal free-play.  The PTO hydraulic clutch gets its oil pressure from the same circuit that operates the Power Director clutch. You're not complaining of Power Director clutch problems, but a pressure check of that part of the tractors hydraulics would be in order to verify proper numbers. Are you SURE the PTO lever remains fully UP when this slippage problem occurs?? Only you can verify this while sitting in the seat. There is a "detent" that is supossed to keep the PTO lever in the fully up and fully down positions. If this detent wasn't working, the lever wouldn't stay fully up for sure. Again, this is on you to figure out. No one else can do it for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gjmac22 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2023 at 5:48pm
Alright I have tested the foot clutch it does stall the tractor I checked linkages best I could but there is not many mechanical linkages I couldn’t even get the pto to spin now seems like the problem has gotten worse I know it’s not my cutter cause it has been hooked up to my 175 and ran perfectly
Edited by gjmac22 - 19 Jun 2023 at 5:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2023 at 5:50pm
A good place to start.   EDIT:  Get a 500 psi gauge and get tapped into one of the two allen head plugs on the side of the Power Director valve. Needs to be 300 psi minimum in both LOW and HIGH ranges and this same pressure makes the PTO clutch work.
Edited by DrAllis - 19 Jun 2023 at 6:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote gjmac22 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2023 at 5:59pm
Is there any cover that can be taken off the underside of the tractor to look at the pto shaft I’ve heard about a locking collar that may back off
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2023 at 6:07pm
Grab the PTO shaft and try and turn it. If it turns really easy, the coupling has disengaged. If it turns with some effort the coupling is still connected.  BUT, it doesn't fix itself and you are complaining of works sometimes/doesn't work sometimes. And that would have to be a separate problem with the PTO clutch or it's hydraulics..
Post Options Post Options   Thanks (0) Thanks(0)   Quote gjmac22 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2023 at 6:18pm
true it just wouldn’t work at all today and I jumped to that conclusion the shaft spins with some resistance
Edited by gjmac22 - 19 Jun 2023 at 7:37pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2023 at 9:19pm
Snap ring has came out of it's Grove in PTO clutch. PTO clutch housing has to come off.                   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2023 at 9:20pm
Sounds like a pressure check needs to be made at the Power Director valve. Check in both low and high range with engine full throttle and record readings and then re-check with PTO on and then off and record readings. PTO on or off shouldn't change the pressures hardly a bit and should be the same ON or OFF.
