200 allis chalmers .
ALK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALK Quote  Post ReplyReply Direct Link To This Post Topic: 200 allis chalmers .
    Posted: 14 Aug 2014 at 8:37pm
I just purchased a 200 allis chalmers . It has a cab , I need a set of fenders . How much can you turn a 200 up with damaging it . I also want to put an sir research t04 on it . I was told it had the lovely high pitched whistle . Any thoughts or opinions are welcomed . Thanks in advance !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2014 at 9:54pm
It already has an Air-Research TO-4 series turbo on it.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2014 at 10:12pm
AC used the formula that an engine/transmission turned up and USED at 110% of rated load would be the equivalent wear of 100 hours per each hour put on the engine.  Bottom the leaf springs and back out the torque screw and then rake hay with it and it will not 'hurt' the tractor but it will use more fuel and suet the engine under no boost conditions.  USE the now about 120 + hp and then refer to the above formula.  Pull the muffler off and get that lovely whistle then after a few days of running go and be fitted for a lovely pair of hearing aids ..........
ALK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2014 at 5:45am
This has a ray jay turbo on it and a straight pipe . It whistles a little , nothing to brag about . It is fixing to get dismantled for a thorough cleaning and repainting . Im going to rebuild the engine and have 3rd gear fixed . Pops out going down a hill .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2014 at 6:01am
Never seen a 200 with a RaJay turbo.......only Air-Research. If you want more whistle, get one from a 7020 tractor.
Slade (TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slade (TN) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2014 at 8:03am
I have one N.O.S. T04 left, put one on a local 200 and the fella commented on the "whistle"......
Slade
615-542-6999
ALK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2014 at 10:56am
I am interested in it . I will give you a call . Thanks
