200 allis cab weatherstriping
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Topic: 200 allis cab weatherstriping
    Posted: 08 Feb 2010 at 1:40pm
I need the door upper window rubber piece that holds the window in. Factory cab btw... Local dealer says it is discontinued. Will the windshield rubber from an old pickup truck work, any other suggestions? dont ask what happened to the original.. Thanks
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 1:46pm
  Do you have a Safelite auto glass installer nearby?  They used to be called Auto Glass Specialist. They should have the seal you need in bulk. Take a sample with you so they can see the profile , should be able to cut off whatever length you need . Gary
