200 Air Conditioner Valves |
dnel45 ![]() Bronze Level ![]() Joined: 13 Oct 2009 Location: Northwest Ohio Points: 164 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Mar 2012 at 9:27am |
A week or so ago there was a thread about putting in a valve on the hot water line that runs to the cab for use during summer air conditioning time. I was looking at our 200 and there are two lines that run to the cab that get warm during operation, one on the right side of the engine from the water pump and one on the left side of the engine from the thermostat/temp sensor. Do you have to put valves on both sides of the tractor to keep the warm water out of the heater?
Background: We just redid the A/C with new 134a compressor, lines, etc., and it isn't as cold as it should be, especially after the tractor is warm. The heater lines running into the cab are warm-hot during operatrion and I believe are killing what my A/C is trying to do.
Hurst ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Midway, Ky Points: 1218 |
Nope, I put mine on the water pressure side. It's a loop, so if you cut off flow to one side, you cut off flow completely. Water pump side was the easiest for me to put a valve on and gave me a way to shut off pressure to those hoses and the heater core, versus putting the valve on the return, where you still have pressure on the heater core and hoses.
Hurst |
1979 Allis Chalmers 7000
5800 Hours |
JW in MO ![]() Orange Level ![]() ![]() Joined: 16 Feb 2010 Location: South KC Area Points: 2666 |
I'm not familiar with the specific system you are working on, however, your heater should have a control that closes a valve in the water line. Only one valve should be necessary but if both lines are HOT it is a possibility that the valve that SHOULD be in there is leaking by and adding heat. If you can locate that valve and give it the touch test you will know. I would think that the temprature control on your heater would regulate how far open or closed the valve is depending on the comfort setting. If you are lucky that control will be manual with a cable and easy to find and work on.
Put a ball valve in the top hose from motor. Most of the cab shutoff valves are junk. Might work to control heat in winter but shut the ball valve off in summer. MACK
Dave H ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central IL Points: 3583 |
Yep that even works on my old teen age powerstroke.
