2 way cyl. for WD45
BV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BV Quote  Post ReplyReply Direct Link To This Post Topic: 2 way cyl. for WD45
    Posted: 27 Nov 2010 at 8:04pm
I would like to use a 2 way cylinder on my WD45 so it's the same as my 175, so what piece do I need to add? Will this work ok or what? Please help me. Any pictures would be great. Thanks again.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 8:10pm
My D17 had a diverter valve on it that would work a two way cyl, until the disk came unhooked and ripped it off. I dont know much about how it worked or where to get one as it happened the first time i hook to it.
acdave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acdave63 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 8:45pm
it can be plumbed in just run another line for the return and send it back into the tank it wont work as good as your 175 but i used to run a 4 row kinzie planter with a series 1 diesel and it would pick up and raise the marker arms just a little slow David
