2 cylinder Buda diesel F.S.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Topic: 2 cylinder Buda diesel F.S.
    Posted: 26 May 2022 at 11:05am
Not Mine seen on Facebook Market place $500
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2022 at 5:25pm
I can’t make it open.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2022 at 6:53pm
when you click on the link, it will put a " /%20 " after the item number on the post... CLick at the END of the title and backspace to eliminate the  /%20, then hit enter...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2022 at 6:56pm
Missing radiator, missing crank handle, missing some fuel lines.
Has some compression, injectors make noise, fuel pump seems to work. Same pistons as a Allis Chalmers B diesel. Bosche injectors. Cool stationary engine or barge motor.
I believe the engine is from the 1940's. I read that the head gasket is copper, valves and pistons are like a Buda Allis engine, so you could get the compression back up.
