2 bottom Disc plow question |
Richardmo
Joined: 12 Sep 2009 Location: Rolla mo. Points: 1747 |
Topic: 2 bottom Disc plow questionPosted: 15 May 2017 at 3:37pm |
I want to mount a 2 bottom Disc plow I have to a WD pin hitch tractor.
I would by a manual if any has one also. one of the question I have, The Disc low I have bolts to the drawbar. does it require the support that holds the drawbar to be removed? Any help appreciated. Thanks, |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55282 |
Posted: 15 May 2017 at 6:14pm |
Bolts to the snap coupler drawbar, and yes, you do remove the bail, otherwise it wouldn't lift/lower...
Make sure the tailwheel ain't worn out, or it will pull side to side, all over the place. A new coulter, will replace the tail wheel cutting edge, nicely...
Richardmo
Posted: 15 May 2017 at 7:40pm |
That what I thought on the drawbar,just wanted to make sure.
Also appears that it had higher bracket not for were it bolts up to. |
