2 14s plow with a B?
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 8:05am
How deep are you plowing Charlie?
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 8:13am
That's a neat photo, Charlie. When you raise the plow up, is there not a tail wheel that stays on the ground? My Oliver 2-12 is that way. It doesn't look like yours has the trailing tail wheel though. That would surely make it easier to back!
Mine was missing the tail wheel. I looked for one but never found one. Sold the plow when I found a 3 point one that I use on my D10/12. Local Oliver guy snatched it up quick.
That was some hard pulling as the ground had never been turned. Made the B grunt!
I think I was 8" deep in the furrow.
That plow was hard to transport as it would wallow back and forth bad. It seems the tongue had a lot of flex?  Does yours transport OK? I ended up using two straps to pull it tight on either side to keep it in line.
Charlie
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 8:36am
I guess that could  be a side effect of not having a tail wheel. Mine pulls very nice in transport, but you can't back it. If you try, it just makes a sharp right and jackknives. Seems the there would be a easier way...
Jonny B 1938 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny B 1938 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 8:52am
I have seen teeter plows but never used one, I would imagine a rigid hitch would be a must to controll draft. I have a caster wheel on mine and as long as I use the tongue with a pin in it I can back it up, it also has a crank on it to raise or lower hitch height to pull the caster off the ground when hitched up.
Edited by Jonny B 1938 - 29 Sep 2016 at 8:59am
