1st time puller ????? |
Kip-Utah
Joined: 14 Sep 2009 Location: Southern Utah Points: 919 |
Topic: 1st time puller ?????Posted: 09 Sep 2013 at 7:21pm |
Let's knock this crap off already!! There is no good reason for anyone to be taking shots at other forum members period. Before long nobody will be willing to respond to any question posted on here!!
mgburchard
Joined: 14 Sep 2009 Location: Tennessee Points: 1123 |
Posted: 09 Sep 2013 at 2:38pm |
video is on page three of a topic started by blue titled well plinko here you go . blue must have selective memory. lol
Edited by mgburchard - 09 Sep 2013 at 7:10pm |
blue924.9
Joined: 22 Mar 2013 Location: George Iowa Points: 1089 |
Posted: 09 Sep 2013 at 2:16pm |
Glockhead SWMI
Joined: 12 Sep 2009 Location: South West Mich Points: 2657 |
Posted: 09 Sep 2013 at 2:01pm |
Video? What video?
mgburchard
Posted: 09 Sep 2013 at 1:27pm |
looks like blue has learned a lot since he started studying the boss man mlpankey video. lol
blue924.9
Posted: 09 Sep 2013 at 8:02am |
AC200Puller
Joined: 04 Dec 2011 Location: Wisconsin Points: 774 |
Posted: 08 Sep 2013 at 6:04pm |
And if there is a drawbar height limit get it up to that and adjust the drawbar as short as you can . I have seen a lot of guys get a spare drawbar and cut it off just behind the saddle and put a new hole in it there.
AC200Puller
Posted: 08 Sep 2013 at 6:01pm |
1st gear would be my choice if it is any kind of track at all and put 200lbs on the front if you have moveable weight.
Dave/cvny
Joined: 11 Sep 2009 Location: Cherry Valley Points: 107 |
Posted: 08 Sep 2013 at 4:09pm |
My first hook I pulled in the 4000 lb, used 2nd gear, got 4th out of 8. Second hook 4500, used 1st, was within 4 or 5ft of the first pull. 8 or 9 in each class. Pulled in the 5 and the 5500 without any more added weight and was still in the 230ft range! Great day! got the bug now!!!
JayIN
Posted: 08 Sep 2013 at 5:38am |
Amen to that!
Posted: 07 Sep 2013 at 9:33pm |
I doubt any stock WD could ever pull 2nd gear unless it was on gravel.
OrangeFever
Joined: 25 Apr 2010 Location: Eastern Iowa Points: 122 |
Posted: 07 Sep 2013 at 7:51pm |
Went on a tractor ride today and rode across a scale. Weighted 3760 with a WD45 wide front including myself at 150 lbs. You'll probably have to pull 4000lbs unless you can shave its weight down. I feel 1st gear would be best for your 1st hook. I personally feel 2nd might be better with a few hooks under your belt.
patrickmull
Posted: 07 Sep 2013 at 6:48pm |
the lowest class you can get in i would pull in low gear to start with
Dave/cvny
Posted: 07 Sep 2013 at 6:42pm |
Going to a local pull tomorrow with my WD which is totally stock with 14.9 x 28 tires. It is a wide front. what weight class can I start out in? What is the best gear to pull in, not sure if there is a speed limit? I do have some weights that I can add to it. Any help will be appreciated!!! Dave C.
