1st time puller ?????
Dave/cvny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave/cvny Quote  Post ReplyReply Direct Link To This Post Topic: 1st time puller ?????
    Posted: 07 Sep 2013 at 6:42pm
Going to a local pull tomorrow with my WD which is totally stock with 14.9 x 28 tires. It is a wide front. what weight class can I start out in? What is the best gear to pull in, not sure if there is a speed limit?  I do have some weights that I can add to it. Any help will be appreciated!!! Dave C.
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2013 at 6:48pm
the lowest class you can get in i would pull in low gear to start with
OrangeFever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeFever Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2013 at 7:51pm
Went on a tractor ride today and rode across a scale. Weighted 3760 with a WD45 wide front including myself at 150 lbs. You'll probably have to pull 4000lbs unless you can shave its weight down. I feel 1st gear would be best for your 1st hook. I personally feel 2nd might be better with a few hooks under your belt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2013 at 9:33pm
I doubt any stock WD could ever pull 2nd gear unless it was on gravel.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2013 at 5:38am
Amen to that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave/cvny Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2013 at 4:09pm
My first hook I pulled in the 4000 lb, used 2nd gear, got 4th out of 8. Second hook 4500, used 1st, was within 4 or 5ft of the first pull. 8 or 9 in each class. Pulled in the 5 and the 5500 without any more added weight and was still in the 230ft range! Great day! got the bug now!!!
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2013 at 6:01pm
1st gear would be my choice if it is any kind of track at all and put 200lbs on the front if you have moveable weight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2013 at 6:04pm
And if there is a drawbar height limit get it up to that and adjust the drawbar as short as you can . I have seen a lot of guys get a spare drawbar and cut it off just behind the saddle and put a new hole in it there.
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2013 at 8:02am
it would, just not for very far, some pointers that i do, half throttle and easy on the clutch release to start, let the govenor do its work, for me in the 3500 i cant go full throttle before 100 feet cause it will overspeed, i usually just run down the middle, try not to use the brakes to steer, and wds and wd 45s seem to like to raise the front end up easier than others, tough the wide front should help, if you are doing a wheelie add more weight to the front for the next pull, you wont have the power usually to run past 4500
mgburchard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgburchard Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2013 at 1:27pm
looks like blue has learned a lot since he started studying the boss man mlpankey video. lol
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2013 at 2:01pm
Video? What video?
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2013 at 2:16pm
to the op, just ignore this post, and also know that there is no "video" that i learned from, i learned from here and experience
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgburchard Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2013 at 2:38pm
video is on page three of a topic started by blue titled well plinko here you go . blue must have selective memory. lol
Edited by mgburchard - 09 Sep 2013 at 7:10pm
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2013 at 7:21pm
Let's knock this crap off already!! There is no good reason for anyone to be taking shots at other forum members period. Before long nobody will be willing to respond to any question posted on here!!Handshake (A little more manley than getting a hug from a little yellow dude!)
This page was generated in 0.123 seconds.
