1991 E4OD
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: 1991 E4OD
    Posted: 18 Aug 2025 at 4:38pm
In my F-350 started shifting funky the past couple days. Friday it slammed into 2nd, and 3rd a couple times, but 3rd into 4th, and 4th into OD was smooth. Now today, around town, when in 2nd and 3rd, occasionally the rpm’s would jump up a few hundred, then drop back down, then ground speed would increase. ATF is at full, always properly checked, nice and pink/red on towel, does not smell burnt. 133,000 miles on the truck, no knowledge on past maintenance history since purchased this past October. I have put just over 4,000mi on it.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2025 at 4:58pm
I would start by replacing fluid and filter, even though it does not smell/look bad
I am still confident of this;
Wait for the Lord;
ScottNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottNC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2025 at 6:58pm
Must be something in the air. I got a 1991 F150 that did the exact same thing Saturday and Monday. Haven't had time to dig into it yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2025 at 8:52pm
The "E" in the spec mean ELECTRONIC SHIFT.... Several INPUTS and then SOLENOIDS engage the trans with oil pressure... you can have a bad INPUT SIGNAL... or a BAD SOLENOID or wire Harness...
Erratic Shifting Behavior
With the E4OD transmission, electrical problems are often the main culprit behind erratic shifting behavior. It’s often due to faulty sensors readings. Wrong readings from a faulty tachometer (which measures RPM), throttle position sensor and vehicle speed sensor can cause the transmission control module to shift gears at the wrong time.
Some E4OD transmissions had issues with the analog range sensors, especially the ones built before 1995 as the poor weather-proofing allowed water to enter the connector and cause electrical problems.
Delayed or No Shifts
Poor cooling and vibration may damage the shift solenoids, and lead to their failure. If this happens, the automatic transmission fluid will not be routed through the valve body properly to engage the right gear.
fjdrill View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote fjdrill Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2025 at 5:03am
Pull the pigtail where it goes into the tranny. If wet replace coil pack. Also, it has speed sensors on top. (same as cam speed) if replace do both with Motorcraft brand. If getting a flash on gear shift and hard shifting probably torque converter coming apart inside and turbines getting locked w/debris. Also. have seen filter drop out/down. replace w/Motorcraft and install with retainer clips added. you can buy the retainers, or I just made them out of thin sheet metal-they are just clips that keep the filter from falling down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2025 at 8:20am
UPDATE: Had my local mechanic( Ford stealerships are worthless for non-warranty work) take a look, he mentioned another customer with exactly same issue, theirs was the ‘throttle position sensor’. Gave that a shot on mine, turns that is what it was. A few minutes to replace, and about an hour or so of adjusting the ohms of the sensor, now shifts better than ever.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 10:10am
You don’t have a 4th-OD shift, 4th is OD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 1:08pm
4th is overdrive... but you have a LOCKUP that takes the torque converter slip out of the picture... that can feel like a "shift" after you are in 4th gear.
This page was generated in 0.187 seconds.
