1984 4 wheel drive Model 5015 |
nhmath
Topic: 1984 4 wheel drive Model 5015Posted: 28 Sep 2023 at 4:56pm |
Hi, When I put the 4 wheel drive lever down It does not engage the fron wheels. Please HELP. Neil
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5453 |
Thanks(1)
Posted: 01 Oct 2023 at 7:07pm |
Haven’t worked on the 4x4 5015, did you follow the lever to see where it goes to make sure you don’t see something that has come loose?
nhmath
Posted: 02 Oct 2023 at 6:31am |
Yes. it seems to try and lock in but at the point of lock in it looks jammed.
AC720Man
Posted: 05 Oct 2023 at 7:05pm |
Can you post a picture of the linkage?
Joined: 11 Sep 2009 Location: illinois Points: 90561 |
Posted: 05 Oct 2023 at 7:24pm |
jammed like the gears are not meshing ? ....Sometimes rolling slowly or bumping the clutch to rock the tractor will allow a gearbox to mesh. ( like a transmission).
nhmath
Posted: 06 Oct 2023 at 7:27am |
Thanks I will give it a try.
nhmath
Posted: 06 Oct 2023 at 7:28am |
Will do as soon as I can.
Jasonw
Posted: 19 Oct 2023 at 5:47am |
The front drive shaft is driven via a sprocket and roller chain on the rear pinion shaft. The chain or keyway for the sprocket could be broken.
