1982 Allis Chalmers tractor hydraulic fluid fill
JamesTc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JamesTc Quote  Post ReplyReply Direct Link To This Post Topic: 1982 Allis Chalmers tractor hydraulic fluid fill
    Posted: 15 Aug 2017 at 8:05pm
Yes I have a 1982 Allis Chalmers tractor my 3 point hitch won't lift anymore and I believe all the fluid has leaked out of the rear end. Does anyone know where to fill it at and if anyone is familiar with this please help
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 8:07pm
It would hwelp if we had an idea which tractor model it is. Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
rustydollar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustydollar Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2017 at 7:22pm
Your problem is not model specific, the trans-axle is also the hydraulic oil reservoir, look under the seat for a pipe plug. A 9/16th " open end will remove the plug, once you have the plug in your hand you'll notice a dip stick has been affixed to the underside.
Use a small funnel to add oil through the open hole from which the pipe plug has been removed. Careful not to over fill.
Edited by rustydollar - 19 Aug 2017 at 7:24pm
This page was generated in 0.157 seconds.
