1979 AC 715 Backhoe |
trucktoys
Topic: 1979 AC 715 BackhoePosted: 19 Mar 2011 at 4:15pm |
Hi:
I am looking at buying an 1979 AC 715 Backhoe. Can some one tell me the weight of this back hoe? Any other info would be helpful. Thanks
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42269 |
Posted: 19 Mar 2011 at 4:27pm |
couple other posts here on 715 machines .
Perkins engine , 4 sp borg warner transmission , torque converter with few/rev clutch pack
14 ft hoe std. 1yd bucket.
say around 12 to 14000 pounds . orbital hyd steering ,
watch for crack on front timing cover by hyd pump , weak sopt if there is not a brace update kit put on to keep hyd pump from flexing housing under heavy load.
Edited by Coke-in-MN - 19 Mar 2011 at 4:28pm |
trucktoys
Posted: 19 Mar 2011 at 4:30pm |
Thank-you!!!
sabdfb
Posted: 22 Jul 2011 at 6:16pm |
i have a 715d with backhoe and loader,trans is blowing fluid back out the overflow.dropped the pan and i had some brass shavings in the fluid.i live in the rapid city sd area and i'm having problems finding someone to work on.also wondering about replacement parts for the funk trans,are they still available?
Coke-in-MN
Posted: 23 Jul 2011 at 11:31am |
Couple people on here have posted on parts , believe someone in MI has a kit for the Fwd/ Rev unit when i checked on mine.
Believe it is like 17 Hrs for R&R of tranys and clutch pack. / If you cant find the old post you can try Herc-U-Lift in Mpls MN as they were a AC dealer on those machines.
Know for sure of who i will not recommend as they took me to cleaners when I had mine done in shop, should have done it myself. Bunch of crooks at Carlson Tractor in Rosemount MN shop.
