1979 175D left brake
Curt IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Curt IA Quote  Post ReplyReply Direct Link To This Post Topic: 1979 175D left brake
    Posted: 21 Jun 2010 at 12:38pm
I was setting the left brake, I heard a pop and the brake pedal flopped over. It seemed to have popped loose from the brake. If nothing is broke is this an easy fix, or do I have to pull the tire and final drive? Can it be reached from the plate on top?
Thanks
Curt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 9:17pm
What broke and where at. Probably broke brake rod where it screws into clevis end. Look at where it enters under foot rest under rear axle housing. That would be most common break. They can be aggravating to say the least. HTH Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 9:24pm
Tracy - one of these days when I get back to Nashville we'll have to synch up on those brake parts.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Curt IA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 10:01pm
No visible breaks, at first I thought the compression roll pin on the pedal had fallen out but no such luck. It is loose inside the axle housing.
Curt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 10:14pm
Curt, Could possibly be the cross bar actuates the brakes. Can you see in there with flashlight and or mirror? Might have to take that side off. Lucky you on that,you don't have to remove hyd. valve assembly. Let us know. Tracy Martin
mark v IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark v  IA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 8:50am
Traci, I've worked on brakes on D17 series 4 several times and it is more crap to work around but never took the hyd assembly off.  I don't think it would be any different on a 175 and another pair of hands do help.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 11:45am
Twisted off the left brake rod on my D17D,had to pull off the whole left side to fix it,with a loaded tire and wheel weight,lotsa fun!
