1978 ac 715D backhoe
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2018 at 7:19am
Have seen almost every ground engagement tool supplier tooth or cutting edge on every machine except Cat, can pretty well replace a lost tooth head on a shank from any distributor so long as you find a knowledgeable parts man that can recognize the types.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2018 at 10:19am
I have a 12" trench bucket from a Ford I modified to fit machine and it takes a small tooth that you use a ball peen hammer to dimple side to attach to shank - on the AC bucket 32" the split pin with rubber center holds tooth to shank . Bought a couple frost teeth to use along with the standard teeth .
Chris Dame View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Dame Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2023 at 9:51am
Would anyone have a 1002958 valve assembly for 715D backhoe? Mine is cracked
This page was generated in 0.293 seconds.
