1978 ac 715D backhoe |
Page <12 |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35630 |
Posted: 02 Sep 2018 at 7:19am |
Have seen almost every ground engagement tool supplier tooth or cutting edge on every machine except Cat, can pretty well replace a lost tooth head on a shank from any distributor so long as you find a knowledgeable parts man that can recognize the types.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42261 |
Posted: 02 Sep 2018 at 10:19am |
I have a 12" trench bucket from a Ford I modified to fit machine and it takes a small tooth that you use a ball peen hammer to dimple side to attach to shank - on the AC bucket 32" the split pin with rubber center holds tooth to shank . Bought a couple frost teeth to use along with the standard teeth .
Chris Dame
Joined: 11 Apr 2023 Location: Grovespring Mo. Points: 8 |
Posted: 12 Apr 2023 at 9:51am |
Would anyone have a 1002958 valve assembly for 715D backhoe? Mine is cracked
Page <12 |
