1977 Allis Chalmer 7020 Belly Color
 Post Reply Post Reply Page  <1234>
1970sFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1970sFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2016 at 2:28pm
Those are really sweet. When the came and got the 7020, heheh, they for the, remember these...Jack screws...those long bolts that you use to pull / push the outer dual off....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1970sFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2016 at 2:29pm
Intrepretation:
when they came for the tractor, they forgot the jack screws....
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2016 at 6:09pm
Originally posted by 1970sFarmer 1970sFarmer wrote:
Here's another head scratcher.
the same man who had the hipper on a AC 190, one day had an implement that was two rows of working parts.
First row were a series of vertical teeth shaped like cotton picker teeth, that rotated on 360' on the vertical plane..this implement was 4 or 6 rows wide...
then a leveler? roller basket or horizontal rotating blades like a do-all...
Ever see or heard of this?
That would probably have been a Rotara, not sure on the spelling. It has forks that rotated back and forth then a rolling basket. Ran off the pto, and was 3 point mounted. Should have been red in color.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2016 at 6:10pm
Intrepretation:
Must have had cast duals. Pusher bolts pushed the wedges off the axial.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2016 at 6:32pm
A friend of mine bought a 7050 new, and not too long afterwards, he was getting sick of the (what he called ugly) maroon paint, so he painted it black. Low and behold, a few years later, A-C began painting the bellies black instead of maroon! That might be the case here....Of course, since the 7020 wasn't out in 1976....I don't know... Pics would be great!
I am also leaning toward a 7040 transmission in a 7020.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2016 at 1:35am
I am going to guess that the tractor was a 1976 Allis 7040 maroon belly, or a 7060.
Also, the implement discussed sounds like a Lely Roterra? Or a Lilliston Rolling Cultivator? google search each and report back which one it is.
Keep digging for photos!
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Dkienzle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dkienzle Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2016 at 8:59pm
Four Post open ROPS....Turn signals and flashers in a white roof, fore and aft.
I love that tractor.
Did yours have flashers in the roof like lons pictures?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2016 at 9:48pm
I could be wrong but I think all the ROPS canopy models were like that for all 7000 series. I also think cabbed models changed to lowered front flashers some time early in the 7040/7060 production.
Wink
I am a Russian Bot
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 10:45am
1970s, did you have the 1066 and 70-whatever at the same time? If the 1066 didn't pull your disk, a 7020 would not have been an upgrade hp wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1970sFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 12:25pm
Closer to the Lely Rotera the lillian rolling cultivator.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 6:41pm
Early 1066 tractors were lower horse powered than 7020 but not by much. maybe 10 hp lower.
Edited by Lonn - 18 Jul 2016 at 6:41pm
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 7:01pm
sometimes we don't remember what things were exactly....I have a 8070 now and my cousins dad bought a new 8030 back in the day.My cousin keeps referring to the 8070 they used to have.....but he is a duffuss
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 8:19pm
The top of the ROPS, was it metal, or fiberglass?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1970sFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 8:46pm
The "1066" was actually the Deutz 100 06, not IH 1066. I apologize if In mislead anyone. The Deutz probably could out pull most tractors of v equitable HP, but with single drives, traction loss was the biggest failure.
Edited by 1970sFarmer - 18 Jul 2016 at 8:47pm
Fiber glass
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 9:12pm
You got me.
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 10:39pm
7030 maybe? Do you remember if the engine had an intercooler on it and if filled the engine compartment when looking at it with the side panels on? The 7020 has a 301 with an intercooler and you can see daylight over the top of the engine where as a 7030 or larger was a 426 cu. and you couldn't see over that engine. How about the idiot lights on the dash....6 small round lights or a plastic 2 by 3 piece cluster?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2016 at 7:42am
Now you are just gonna have to try and find pics. And as I said before, we all love pics.
I think all non-cab, ROPS models, be it maroon belly or black, had a fiberglass top with the flasher lights in the top. All cabbed 7030 and 7050 had the fiber glass top. I think all later cabbed models had a metal top. Unsure about the very early 7040, 7060, 7080 as far as cab tops go. There is a 7040 on tractor house with the flashers in the cab top on front. I think I have sales brochures showing some 7040/7060 models with flashers in cab top but parts book only shows metal top parts number for cabbed models. All ROPS non-cab show part number for fiber glass top.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dkienzle Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2016 at 2:35pm
I wonder if he would remember what side of the tractor the starter was on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1970sFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2016 at 2:48pm
I don't think so, although interested in tractors, I didn't know much about them...
like, intercoolers, I knew what a turbo was, but which side a starter was on....don't think so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2016 at 2:52pm
Which side the engine oil filters were on??
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1970sFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2016 at 3:11pm
Not saying it happened, but when did Allis introduce 7030 and the 7020, because I wonder if we got a re-sklinned 7030 to 7020 and not a 7020...Was the 7030 maroon bellied?
Also,
why did Allis introduce the 7000 series like they did...
I always thought the sequence was 7000,7010,7020,7030,7040,7050,7060,7080...
but I gleaned that the sequence was more(1973-1974) 7030-7050,(1975-1979)7000-7040,,('74-1981)7060,(1978-1981)7020 -7045-7080.
Could someone explain.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2016 at 3:14pm
sequence wise you are correct but they were not all released at the same time and some models were replaced by others
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1970sFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2016 at 3:29pm
They made it as confusion as hades in winter...
Edited by 1970sFarmer - 19 Jul 2016 at 3:32pm
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2016 at 3:56pm
Whew. Glad you guys got the dust settled. Sure stirred up my allergies.  LOL
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2016 at 5:20pm
Also,
I think I'd take a 7030 over a 7020, not that the 7020 was a bad tractor. The 7030 is just a bit more tractor.
7030/7050 = January 1973 thru sometime in 1974,
7040/7060/7080 maroon belly = 1974 thru 77
7000 maroon = 1975 thru 1978
7020/7045/7060/7080 black belly = 1977-81
7000 black belly 1978 thru 1979
7010 black belly = 1979 thru 81
 At least that is what I think is right.
Wink
I am a Russian Bot
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2016 at 7:12pm
I haven't seen this much interest in belly color since "I Dream of Jeannie" premiered!
Ddddddddamn right!
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2016 at 8:39pm
A couple of my observations. I consider all 7030 & 7050 to be 1973 or 1974. Only 1973 models had the black face cab. These tractors had a plastic roof with the flashers in them. I call the first year 7040-7060-7080s 1975 models. They still used the plastic roof. 1976 was the first metal roof. I think that 1976 was also the first power shift.1977 models had a different dash, rectangular, electronic idiot lights instead of the six individual round lights. They had a much larger power shift filter also. 1978 was the first black belly. 7020-7045-7060-7080. They had the accousta cab 2,larger steps, but still used a steel fuel tank. The gear shift lever was moved to the side in 1978 on the power directors. 1979s went to a plastic fuel tank. 1981s used the Bosch injectors. The straight 7000 were 1976 & 1977 maroon belly with a dry clutch. 1978 7000 was black belly and used the first speed of the power director as an inching clutch. The last year of the 7000,those tractors used a larger muffler, like the larger framed tractors. The earlier ones just used a round muffler like a 200. The 7010 took the place of the 7000 in 1980 as I recall. I consider 1982 to be the first year of the 8000s. These are just for my reference. Actual dates when the models were introduced may be different from what I perceive them to be. Many other improvements and updates were added thru the years and did not necessarily correspond to any specific years model.
Edited by Lynn Marshall - 19 Jul 2016 at 8:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1970sFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2016 at 5:52am
I have my mom and sister looking, or hope to..my dad needs mom's help alot.  I know I have 8mm movies of our Deutz and Massey, I hope to have at least a photo of the 7020...
Guys, I really appreciate all the responses to this conun
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2016 at 6:39am
8000 series had build dates in December 1981 I believe. They are considered 1982 models I suppose. I always go by the build date myself to determine year of tractor.
Wink
I am a Russian Bot
This page was generated in 0.281 seconds.
